hello
when I try to use /*v.out.ogr as:*//* */
v.out.ogr input=jeo6 type=area dsn="PG:host=localhost dbname=bzk user=orkun" olayer=sil format=PostgreSQL
it gives:
Error: value <PostgreSQL> out of range for parameter <format>
Legal range: ESRI_Shapefile,TIGER,S57,MapInfo_File,DGN,Memory,CSV,GML
what can I do to solve the problem *
regards
Ahmet Temiz
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster@deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
Hello orkun,
On Thu, 25 Aug 2005 15:56:34 +0300 orkun <temiz@deprem.gov.tr> wrote:
hello
it gives:
Legal range:
It says that your OGR-Version is lacking Postgresl-Support.
So you should recompile gdal/ogr with postgresql-support.
or, if you are on debian
apt-get install gdal-bin libgdal1 python-gdal
Best
Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl@gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
Stephan Holl wrote:
Hello orkun,
hello
it gives:
Legal range:
Best
Stephan
thank you
I recompiled both grass61 and gdal.
Now v.out.ogr gives new error.
after entering db.connect driver=pg database=bzk,
v.out.ogr input=jeo6 type=area dsn="PG:host=localhost dbname=bzk user=orkun" olayer=sil7 format=PostgreSQL
ERROR 1: AddGeometryColumn failed for layer sil7, layer creation has failed.
ERROR: Cannot create layer
( is "user=orkun" wrong ?)
what might possible problems be ?
regards
Hello orkun,
failed. ERROR: Cannot create layer
It looks like this db does not have postGIS enabled?!
So enable the db with postgis-support.
If you just want to store attribute-information have a look at the
newly created wiki-entry[1].
There ist describes how to set up postgres for attribute storage.
hth
Stephan
[1]
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassSixTutorialFaq#11_Use_Postgres_as_attribute_sto
Stephan Holl wrote:
Hello orkun,
hth
Stephan
[1]
thank you
the db I used (bzk) has already been enabled with postGIS.
as "user postgres" in sql environment (out of grass), it works.
bzk=# CREATE TABLE gtest3 ( ID int4, NAME varchar(20) );
CREATE TABLE
bzk=# SELECT AddGeometryColumn('gtest3','geom',-1,'POLYGON',2);
addgeometrycolumn
public.gtest3.geom SRID:-1 TYPE:POLYGON DIMS:2
geometry_column fixed:0
(1 row)
the problem (I think) is related to:
my newer postgresql (8..) version enabled postgis. But grass only connects
older postgre (7.4..). So how can make grass work only newer postgresql ?
how about different user other than user postgres in using v.out.ogr ?
regards
Hello orkun,
CREATE TABLE
addgeometrycolumn
(1 row)
So it "should" work with grass as user postgres as well.
connects older postgre (7.4..).
Have a look at the postgres-manual with special reference to the
SQL-command "GRANT". There you can grant different rights to different
users. Or use a GUI like pgadmin3[1].
This should solve your problems regarding the user-problem.
Since I have not used postgres8 yet (because it not yet in
debian-testing), I cannot help you on this topic.
hth
Stephan
[1] http://www.pgadmin.org
