[GRASSLIST:810] postgres connection
How do I set up grass 5.1 so that v.in.ogr will import the data into a
postgres table? I have found several tutorials, but they all deal with
taking existing grass data and inserting it into a database.
I'm sure it's simple, but I couldn't find the grass 5.1 documentation for
it.
-M
The reason I want to go straight to postgres is because when I try to
import using dbf, the dbf process grows up to 1000 megs before I kill it.
I don't know if I have enough memory to import the CompleteChain layer.
Is this something that will definately require a lot of memory?
-M
it.
-M
-M
> it.
> -M
You can define driver/database by v.database driver=name database=name,
but the database must exist before (it is not created by GRASS).
Dbf driver creates table in the memory and writes it to disk when driver
is closed, it may be also some memory leakage there.
Do you have a large layer? How many features? I worry that postgres
will be too slow for large data sets.
Radim
> -M
> > it.
> > -M
It looks like that worked. I am importing the CompleteChain layer from
the tiger2k files, for the entire state of New Jersey, USA.
I also have some mapinfo tables, but they do not have as much information
as the tiger2k files.
-M
