hello
Sory to ask same problem again.
But the problem with grass-postgresql still continues.
Although postmaster works normally out of grass:
$ /usr/local/pgsql/bin/postmaster -D /usr/local/pgsql/data -p 5432
LOG: database system was shut down at 2005-08-29 14:23:59 EEST
LOG: checkpoint record is at 0/12C5AC04
LOG: redo record is at 0/12C5AC04; undo record is at 0/0; shutdown TRUE
LOG: next transaction ID: 5175; next OID: 3851158
LOG: database system is ready
I can enter the database with :
psql sil
But:
connection from grass to postgresql fails:
db.tables driver=pg database=sil
DBMI-Postgres driver error:
Cannot connect to Postgres: could not connect to server: No such file or directory
Is the server running locally and accepting
connections on Unix domain socket "/var/run/postgresql/.s.PGSQL.5432"?
how can I solve the problem ?
regards
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster@deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
