[GRASSLIST:8115] v.surf.rast
I have run this in the past with success several times. This time
around i'm not sure what i'm doing wrong.
My input parameters into the GUI are: vector file name (vector
contours), name of column (i have used the column with integer values
and floating point), and an output raster of surface, and an output
raster of the slope. Everything else is left default.
when i run the module, i get the following error:
Percent complete:
GRASS_INFO_ERROR(24024,1): Cannot find z column (please verify name)
Loading data from attribute table . . .
Any ideas? I have double/triple/quadruple checked the values in the
colum for interpolation, and they are there and valid.
Please copy and paste the command line (From the bottom of the GUI window,
after you run it, it displays the actuall cli)
Thomas Colson
North Carolina State University
Department of Forestry and Environmental Resources
(919) 673 8023
tom_colson@ncsu.edu
Calendar:
www4.ncsu.edu/~tpcolson
-----Original Message-----
From: owner-GRASSLIST@baylor.edu [mailto:owner-GRASSLIST@baylor.edu] On
Behalf Of M S
Sent: Monday, August 29, 2005 8:09 AM
To: GRASS mailing list
Subject: [GRASSLIST:8115] v.surf.rast
I have run this in the past with success several times. This time around
My input parameters into the GUI are: vector file name (vector contours),
name of column (i have used the column with integer values and floating
point), and an output raster of surface, and an output raster of the slope.
Percent complete:
GRASS_INFO_ERROR(24024,1): Cannot find z column (please verify name) Loading
Any ideas? I have double/triple/quadruple checked the values in the colum
v.surf.rst input=topopostwet layer=1 zcolumn=c2cont dmax=2.035683
dmin=0.407137 elev=surfpostwet slope=slopepostwet zmult=1.0
tension=40. smooth=0.1 segmax=40 npmin=200
Authors: original version - H.Mitasova, L.Mitas, I. Kosinovsky, D.P. Gerdes
See manual pages for reference and publications T3
Percent complete:
Loading data from attribute table ...
Thomas Colson
(919) 673 8023
tom_colson@ncsu.edu
Calendar:
Behalf Of M S
Percent complete:
I don't have Grass running... But try it using the CLI (command line
interface, which you should know how to use anyway). The GUI, in my personal
opinion, isn't always the ideal method for running tools.
When you do it via the CLI, cut 'n paste that command, but drop
zcolumn=c2cont. Layer=1 should pick up the z col automagically. If that
doesn't work, COPY your layer and rename the c2cont field to z.
Thomas Colson
(919) 673 8023
tom_colson@ncsu.edu
Calendar:
Sent: Monday, August 29, 2005 8:19 AM
To: Tom Colson
Cc: GRASS mailing list
Subject: Re: [GRASSLIST:8115] v.surf.rast
dmin=0.407137 elev=surfpostwet slope=slopepostwet zmult=1.0 tension=40.
Percent complete:
Cannot find z column (please verify name) Loading data from attribute table
window, after you run it, it displays the actuall cli)
Thomas Colson
(919) 673 8023
tom_colson@ncsu.edu
Calendar:
On Behalf Of M S
and floating point), and an output raster of surface, and an output raster
of the slope.
Percent complete:
d’oh. i should have known the column name was case sensitive… on my way
On 8/29/05, Tom Colson <tomd_colson@ncsu.edu > wrote:
I don’t have Grass running… But try it using the CLI (command line
opinion, isn’t always the ideal method for running tools.
doesn’t work, COPY your layer and rename the c2cont field to z.
Thomas Colson
(919) 673 8023
tom_colson@ncsu.edu
Calendar:
To: Tom Colson
Percent complete:
Thomas Colson
(919) 673 8023
tom_colson@ncsu.edu
Calendar:
On Behalf Of M S
around i’m not sure what i’m doing wrong.
of the slope.
Percent complete:
On Mon, Aug 29, 2005 at 08:00:50PM -0400, M S wrote:
d'oh. i should have known the column name was case sensitive... on my way
I have changed the error message to
ERROR: Cannot find z column <c2cont> (please verify name, e.g. with v.info)
Maybe helpful for the future.
> personal
> Thomas Colson
> (919) 673 8023
> tom_colson@ncsu.edu
> Calendar:
> www4.ncsu.edu/~tpcolson <http://www4.ncsu.edu/~tpcolson&gt;
> From: M S [mailto:mseibel@gmail.com]
> To: Tom Colson
> Gerdes
> Percent complete:
> table
> > Thomas Colson
> > (919) 673 8023
> > tom_colson@ncsu.edu
> > Calendar:
> > On Behalf Of M S
> raster
> of the slope.
> > Percent complete:
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
nice! thanks!
ERROR: Cannot find z column (please verify name, e.g. with v.info)
personal
Thomas Colson
(919) 673 8023
tom_colson@ncsu.edu
Calendar:
www4.ncsu.edu/~tpcolson < http://www4.ncsu.edu/~tpcolson>
To: Tom Colson
dmin= 0.407137 elev=surfpostwet slope=slopepostwet zmult=1.0 tension=40.
Gerdes
Percent complete:
table
Thomas Colson
(919) 673 8023
tom_colson@ncsu.edu
Calendar:
www4.ncsu.edu/~tpcolson <http://www4.ncsu.edu/~tpcolson>
On Behalf Of M S
raster
of the slope.
Percent complete:
Markus Neteler http://mpa.itc.it
