>>> Michele wrote:
>>>>>> If you reinstall postgres from source you have to manually
>>>>>> rebuild the database directory, user, etc..
>>>>>> You have to follow carefully this instructions:
>>>>>> http://www.postgresql.org/docs/7.4/static/creating-cluster.html
>>>>>> http://www.postgresql.org/docs/7.4/static/postmaster-start.html
>>>>>> you will also have to create a new database user and remember to
>>>>>> use the database administrator user (eg postgres)
>>>>>> postgres$ initdb -D /usr/local/pgsql/data
>>>>>> to do administration task like starting and stopping the postmaster.
>>>>>> Michele.
>>>>> thank you
>>>>> I can run new postgresql alone using postmaster and psql.
>>>>> But grass cannot connect to new postgre, although I have
>>>>> recompiled grass with new path of postgresql.
>>>>> Ahmet
>> There is no -i flag which means that Postgresql doesn't work in
>> TCP/IP mode. This can be enabled in postgresql.conf
>> Markus
> thank you markus,
> when I start postmaster with the port which grass is listening postgre
> db from
> grass works on postgredb.
hello
sorry for multiple mails
I found a answer to my last question.
using an soft link, I can listen postgredb at the same time with grass
and psql
is there any better way ?
regards
Ahmet
This looks to me strange, indeed I can use both psql and Grass to connect to postgres without doing your trik, maybe reinstalling postgres and grass you unintetionally changed some config or variable related to the port postgres/grass/your_system uses.
Again informations you send are too weak to understand where the problem came from...anyway now it works
and I thinks it'll work in another machine with a fresh intall, BTW where did you compile? Linux (distribution?) cywin?
Michele.
____________________________________________________________
Libero Flat, sempre a 4 Mega a 19,95 euro al mese!
Abbonati subito su http://www.libero.it
Michele wrote:
Michele wrote:
If you reinstall postgres from source you have to manually rebuild the database directory, user, etc..
you will also have to create a new database user and remember to use the database administrator user (eg postgres)
Michele.
thank you
Ahmet
thank you markus,
when I start postmaster with the port which grass is listening postgre db from
hello
using an soft link, I can listen postgredb at the same time with grass and psql
regards
Ahmet
Michele.
Libero Flat, sempre a 4 Mega a 19,95 euro al mese! Abbonati subito su http://www…libero.it
you are right
initially, postgresql was installed as debian package.
But later I decided to install postgis, used source code of newest postgresql (8.03),
and not uninstall previous version of postgresql (7.4).
after installing postgresql I reinstalled grass with new path of postgresql.
But the problem I asked arouse. grass looked for old postgresql server.
Even I run new postmaster and later I removed old postgresql from system.
grass is now listening db from old postgresql's port at /var/run/postgresql.
Is there any way to order grass to listen pg/db from any port I prefer ?
regards
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster@deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
