[GRASSLIST:815] importing tif file - Segmentation fault (core dumped)
Hello
I'm trying to import a tif file with r.in.gdal.
It seems that everything goes right but when it begins
to import I have the following message:
Does anyone know how to solve it?
Thank you very much!
   Florent
___________________________________________________________
Do You Yahoo!? -- Une adresse @yahoo.fr gratuite et en français !
Yahoo! Mail : http://fr.mail.yahoo.com
Florent AUBIN wrote:
Hello
  Florent
I have had a similar problem with SDTS files and r.in.gdal. I submitted a bug report and did some troubleshooting.
It seems that there is a memory leak that causes r.in.gdal to overwrite itself and cause a segmentation fault.
I had done some debugging and isolated it to a certain file/subroutine.
The source code is probably not being intepreted the same on different C platforms. On one it works and on redhat 7.3/9.0 it gives a segmentation fault.
Here is the link to the bug report:
http://bugzilla.remotesensing.org/show_bug.cgi?id=359
