hello
my map region is in lon/lat projection.
how can I get utm values of this region ?
regards
Ahmet Temiz
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster@deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
Ahmet, use v.in.region to create a box in your latlong location of your current region. Open up a utm location, and v.proj in that box. Then use v.info for information about the box that you just projected.
There may be an easier solution, but this one will work at least.
G'luck
-Ian
On Sep 1, 2005, at 11:49 PM, orkun wrote:
hello
regards
Ahmet Temiz
What happens if a big asteroid hits Earth? Judging from realistic simulations involving a sledge hammer and a common laboratory frog, we can assume it will be pretty bad.
- Dave Barry
This message has been scanned by anti-virus software.
or you can just use proj directly on the corners, something like this:
echo -122.5 47.0 | proj +proj=utm +zone=10
David
G'luck
-Ian
> hello
> regards
> Ahmet Temiz
> sender's own
> olarak T.C.
> nitelikte degildir.
- Dave Barry
David Finlayson
Marine Geology & Geophysics
School of Oceanography
Box 357940
University of Washington
Seattle, WA 98195-7940
USA
Office: Marine Sciences Building, Room 112
Phone: (206) 616-9407
Web: http://students.washington.edu/dfinlays
