[GRASSLIST:8159] v.in.ascii problem
Dear all,
I know this is surely trivial but I got stuck at the very beginning. Why do I get this message even when trying to import an ascii file, as described in the manual?
v.in.ascii input=/Users/Stefania/Almere/PERMANENT/points3d.txt output=mypoints3d1 format=point fs=| 'columns=x double, y double, z double, label_cz varchar(20), label_en varchar(20)' x=1 y=2 z=3 cat=0 -z
Maximum input row length: 101
Maximum number of columns: 5
Minimum number of columns: 0
x column number > minimum last column number
Yours,
stefania
Stefania Merlo
Department of Archaeology
University of Cambridge
United Kingdom
e-mail: sm399@cam.ac.uk
Office: +44 1223 763518
Mobile: +44 787 6405064
-z
You usually get this error when the field separator (fs=) is wrong.
Check your input file.
If run from the command line be sure to quote the | char otherwise the
shell interprets it as a pipe command. e.g. fs='|'
Hamish
