[GRASSLIST:8160] Re:v.in.ascii problem
I get this message even when trying to import an ascii file, as described
in the manual?
v.in.ascii input=/Users/Stefania/Almere/PERMANENT/points3d.txt
output=mypoints3d1 format=point fs=| 'columns=x double, y double, z double,
label_cz varchar(20), label_en varchar(20)' x=1 y=2 z=3 cat=0 -z
Maximum input row length: 101
Maximum number of columns: 5
Minimum number of columns: 0
x column number > minimum last column number
Yours,
stefania
Hi Stefania,
be sure to give one and only one "carriage return" at the end of last row in your data file, this may solve the problem.
Michele.
____________________________________________________________
Libero Flat, sempre a 4 Mega a 19,95 euro al mese!
Abbonati subito su http://www.libero.it
