[GRASSLIST:8194] Re:libgrass_gmath.so error on startup (FC4)
I've installed everything
as root, and the owner and group of all the files is root.
If you use a normal user account maybe you can't work on data owned by root...
The error message is:
GRASS 6.0.1 (spearfish60):~/grass > Error in startup script: >ps.map:
error while loading shared libraries:
/usr/local/grass-6.0.1/lib/libgrass_gmath.so: cannot restore segment
prot after reloc: Permission denied
    while executing
"exec ps.map -p"
    (procedure "DmPrint::init" line 14)
    invoked from within
"DmPrint::init"
    (procedure "main" line 32)
    invoked from within
"main $argc $argv"
    (file "/usr/local/grass-6.0.1/etc/dm/d.m.tcl" line 894)
Thanks for any help.
-Chris.
____________________________________________________________
6X velocizzare la tua navigazione a 56k? 6X Web Accelerator di Libero!
Scaricalo su INTERNET GRATIS 6X http://www.libero.it
