[GRASSLIST:8228] Nviz problem
I think I might be experimenting problems similar to Benjamin Ducke (July 2005) with the visualisation of volumes in Nviz. I cannot visualise volumes!!! I tried with my own data and then with the Slovakia rainfall, as suggested, but nothing appears on the screen and this is the message I get on the Xterm. I am in fact using Grass 6.0 on macosX as wonderfully compiled by Lorenzo Moretti.
Can anyone help? My thesis is all about the use of GRASS GIS for the analysis and visualisation of archaeological data and it would be a real pity to be able to model but not display things.
Loading Data
translating colors from fp
recalculating normals...
nviz(18742,0xa000ef98) malloc: *** Deallocation of a pointer not malloced: 0x2fb8aa8; This could be a double free(), or free() called with the middle of an allocated block; Try setting environment variable MallocHelp to see tools to help debug
nviz(18742,0xa000ef98) malloc: *** Deallocation of a pointer not malloced: 0x2fbdb48; This could be a double free(), or free() called with the middle of an allocated block; Try setting environment variable MallocHelp to see tools to help debug
nviz(18742,0xa000ef98) malloc: *** Deallocation of a pointer not malloced: 0x30778c8; This could be a double free(), or free() called with the middle of an allocated block; Try setting environment variable MallocHelp to see tools to help debug
nviz(18742,0xa000ef98) malloc: *** Deallocation of a pointer not malloced: 0x322aa88; This could be a double free(), or free() called with the middle of an allocated block; Try setting environment variable MallocHelp to see tools to help debug
% BROWSER: .fbrowse TYPE: vol MODE: 1
nviz(18742,0xa000ef98) malloc: *** Deallocation of a pointer not malloced: 0x3378ac8; This could be a double free(), or free() called with the middle of an allocated block; Try setting environment variable MallocHelp to see tools to help debug
nviz(18742,0xa000ef98) malloc: *** Deallocation of a pointer not malloced: 0x3044cc8; This could be a double free(), or free() called with the middle of an allocated block; Try setting environment variable MallocHelp to see tools to help debug
nviz(18742,0xa000ef98) malloc: *** Deallocation of a pointer not malloced: 0x303cc88; This could be a double free(), or free() called with the middle of an allocated block; Try setting environment variable MallocHelp to see tools to help debug
Stefania Merlo
Department of Archaeology
University of Cambridge
United Kingdom
e-mail: sm399@cam.ac.uk
Office: +44 1223 763518
Mobile: +44 787 6405064
