[GRASSLIST:8239] Is there an upper limit to size of dbf the dbf driver can handle?
I've been working with really big text files consisting of DGPS navigation
feeds for surveys about 2 weeks in length. At 2-second resolution, the file
has something like 254,000 records, way too big for OpenOffice. Can the dbf
driver create and edit a dbf of this size?
~ Eric.
Eric Patton
Technologist, Geo-Spatial Data Services
Geological Survey of Canada (Atlantic)
Natural Resources Canada
Bedford Institute of Oceanography
Dartmouth, Nova Scotia, Canada B2Y 4A2
Postal address: P.O. Box 1006
Courier address: 1 Challenger Drive
Telephone: (902)426-7732
Facsimile: (902)426-4104
E-mail: <mailto:epatton@NRCan.gc.ca> epatton@NRCan.gc.ca
navigation feeds for surveys about 2 weeks in length. At 2-second
resolution, the file has something like 254,000 records, way too big
for OpenOffice. Can the dbf driver create and edit a dbf of this size?
Yes, but better to use GRASS 6.0.1 or 6.1-cvs.
LIDAR data with up to 3 million points has been tested successfully with
the DBF driver and v.in.ascii. 300k points should pose no problem.
I don't have much experience with v.in.db but if anything it should be
smoother although probably has the same memory bottleneck "registering
lines".
Other databases (eg PostgreSQL) might do a better job at dealing with
large datasets. [but I'm not a DB person so don't take my word for it]
Hamish
