I've just installed on a DELL sever with Fedora the GRASS binaries for Fedora Core 3, but GRASS is not working properly:
When it starts d.m I receive the following error:
> d.m&
> Error in startup script: ps.map: error while loading shared libraries: libgdal.so.1: cannot open shared object file: No such file or directory
while executing
"exec ps.map -p"
(procedure "DmPrint::init" line 14)
invoked from within
"DmPrint::init"
(procedure "main" line 32)
invoked from within
"main $argc $argv"
(file "/usr/local/grass6.0.0-i686-pc-linux-gnu-14_03_2005/etc/dm/d.m.tcl" line 894)
[1]+ Exit 1 d.m
Similar error with nviz
> nviz
nviz: error while loading shared libraries: libgdal.so.1: cannot open shared object file: No such file or directory
Any solution?
Thanks, Giacomo
Giacomo Bertoldi
Dept. of Civil and Environmental Engineering
Duke University
This might just be a problem with libraries names. search for libgdal.so and make a link to it named libgdal.so.1 in the same directory.
hope this helps
regards
Carlos
On 9/12/05, Giacomo Bertoldi <giacomo.bertoldi@ing.unitn.it> wrote:
I’ve just installed on a DELL sever with Fedora the GRASS binaries for
d.m&
or directory
while executing
“exec ps.map -p”
(procedure “DmPrint::init” line 14)
invoked from within
“DmPrint::init”
(procedure “main” line 32)
invoked from within
“main $argc $argv”
(file
“/usr/local/grass6.0.0-i686-pc-linux-gnu-14_03_2005/etc/dm/d.m.tcl”
line 894)
[1]+ Exit 1 d.m
nviz
Any solution?
Thanks, Giacomo
Giacomo Bertoldi
Duke University
Carlos Henrique Grohmann - Guano
Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
I think setting LD_LIBRARY_PATH to include the library's path may help.
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/bin
export LD_LIBRARY_PATH
Put the above in your login script to make it always available.
-Chris.
Giacomo Bertoldi wrote:
> d.m&
while executing
"exec ps.map -p"
invoked from within
"DmPrint::init"
invoked from within
"main $argc $argv"
[1]+ Exit 1 d.m
> nviz
Any solution?
Thanks, Giacomo
Giacomo Bertoldi
Duke University
Hi Giacomo,
> d.m&
or directory
while executing
"exec ps.map -p"
invoked from within
"DmPrint::init"
invoked from within
"main $argc $argv"
(file
line 894)
[1]+ Exit 1 d.m
> nviz
Any solution?
This error can be due to two problems:
1) you forgot to install gdal
2) fedora searches the gdal libraries where they aren't. There are several
ways to solve this. You could search with:
locate libgdal.so.1
where the libs are on your system and link them to a folder where fedora for
sure finds them.
ex. libs is in /usr/local/lib and you link it to /usr/lib
as root:
ln -s /usr/local/lib/libgdal.so.1 /usr/lib/libgdal.so.1
Ciao,
HydroloGIS
PS: probably if the problem is the second, you will experience the same with
the proj.
Thanks, Giacomo
Giacomo Bertoldi
Duke University
____________________________________________________________________________
HydroloGIS - Environmental Open Source Solutions
Via Siemens, 19
39100 Bolzano
www.hydrologis.com
Silvia Franceschi
tel: +390471068066
mobile: +393384501332
email: silvia.franceschi@hydrologis.com
Thanks it works.
I did, as you suggested:
as root:
ln -s /usr/local/lib/libgproj.so.1 /usr/lib/libgproj.so.1
On 13 Sep 2005, at 1:24, Silvia Franceschi wrote:
Hi Giacomo,
d.m&
or directory
while executing
"exec ps.map -p"
invoked from within
"DmPrint::init"
invoked from within
"main $argc $argv"
(file
line 894)
[1]+ Exit 1 d.m
nviz
Any solution?
locate libgdal.so.1
sure finds them.
as root:
Ciao,
HydroloGIS
the proj.
Thanks, Giacomo
Giacomo Bertoldi
Duke University
-- ____________________________________________________________________________
Via Siemens, 19
39100 Bolzano
www.hydrologis.com
Silvia Franceschi
tel: +390471068066
Giacomo Bertoldi, Ph.D.
Duke University
E-MAIL: bertoldi@duke.edu
PHONE: +1 919 660 5559
