[GRASSLIST:8267] Init.sh problem GRASS5.3
Hi everyone,
I modified the source of i.rectify command in GRASS 5.3 (modification done - commented the round off stmts)
After i compiled it using gmake53 and gmakelinks53 and then re-enter grass location it works fine on my PC.
But when i tried it on other PC , and entered grass by typing grass53, it directly executes i.rectify at the command prompt.
Enter the group containing files to be rectified
Enter 'list' for a list of existing imagery groups
Enter 'list -f' for a verbose listing
Hit RETURN to cancel request
I think its a GRASS initialisation problem.
Can anyone tell me if my init.sh is getting corrupted and if yes then why? and has .bashrc got to do something with this.
Thanks
Nagesh V Bhatkar
Project Assistant
Physical Oceanography Division
National Institute of Oceanography
India-Goa
Ph.no.: +91 0832 2450306 (Off)
      : +91 0832 2461184 (Res)
Email : bnagesh@nio.org
        nagesh_bhatkar@yahoo.com
On Wed, 14 Sep 2005, Nagesh Bhatkar wrote:
Hi everyone,
What steps did you follow exactly?
Sounds like you have somehow overwritten the file $GISBASE/etc/front.end with your re-compiled i.rectify. Note that all the files in $GISBASE/bin are links to this. The actual programs are in $GISBASE/etc/bin/cmd or $GISBASE/etc/bin/inter. Some commands like i.rectify have both a command-line and interactive version so there is a version in both directories.
Paul
Hi everyone,
Paul
Hello Paul,
Steps followed were:
First i installed GRASS5.3 successfully on the other system. I say successfully because
all the commands as well as my add-on modules (d.rast.edit_hydra) works fine after installation.
Then i went to the source code of i.rectify command found in ~/grass-5.3.0/src/imagery/i.rectify2
I deleted all the object file directories (OBJ.i686-pc-linux-gnu) from i.rectify2 directory and
from the cmd and inter directory.
(cmd and inter directories are in the i.rectify2 directory)
Then i went to the inter directory and modified the ask_wind.c program file. (modification
done: commented round off stmts)
Then i went back to the imagery directory ~/grass-5.3.0/src/imagery and ran
gmake53 i.rectify2
gmakelinks53 i.rectify2
Then i copied the executable formed ~/grass-5.3.0/dist.i686-pc-linux-gnu/etc/bin/inter/i.rectify
to my grass bin ~/grass53/bin
After which i ran grass by typing grass53
The first screen giving location and mapset was displayed allright.
After pressing <ESC> <ENTER> to enter grass , i got this instead
Regards
Nagesh V Bhatkar
Project Assistant
India-Goa
That is your problem. It should go in the etc/bin/inter directory. All the files in bin/ are hard links to etc/front.end so it has been overwritten.
If you copy etc/front.end over from your working installation that may fix the problem with it being overwritten, or perhaps re-run make install.
Paul
Paul
Hello Paul,
Thanks a lot. The problem is solved. As u told me to do , after recompiling, i copied the executable ~/grass-5.3.0/dist.i686-pc-linux-gnu/etc/bin/inter/i.rectify into my ~/grass53/etc/bin/inter directory
and everything works fine now.
Regards
Nagesh V Bhatkar
Project Assistant
India-Goa
