[GRASSLIST:8275] exporting to PostGIS
Hi list,
I'm trying to export a vector in PostGis with the command v.out.ogr.
My Location is Gauss-Boaga with the follow PROJ_INFO file:
datum: rome40
datumparams: towgs84=-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68
proj: tmerc
ellps: international
a: 6378388.0000000000
es: 0.0067226700
f: 297.0000000000
lat_0: 0.0000000000
lon_0: 9.0
k_0: 0.9996000000
x_0: 1500000.0000000000
y_0: 0.000000000
I wrote:
v.out.ogr input=t_comuni_2003 type=area dsn="PG:host=192.168.0.10
dbname=faunalia user=########## password=########" olayer=prova_comuni
layer=1 format=PostgreSQL
The output message said:
Exporting 313 areas (may take some time) ...
100%
313 features written
All seem rigth but if I look the table in PostGIS I see that the SRID is 32767
(a value that not exist in the EPSG codes) and not the correct SRID code
26591 .
So if I use MapServer to display the PostGIS table I see the map not in the
correct place.
The control is with shapefiles exported from GRASS vector of the Location
Gauss-Boaga.
The strange is that if I load the table of PostGIS in QGIS I look it in the
correct place.
The control is with GRASS vector of the Location Gauss-Boaga
There is an option to use in v.out.ogr to put the correct SRID or somethings
else?
Thanks
Leonardo
Leonardo Lami
lami@faunalia.it www.faunalia.it
Via Colombo 3 - 51010 Massa e Cozzile (PT), Italy Tel: (+39)349-1310164
GPG key @: hkp://wwwkeys.pgp.net http://www.pgp.net/wwwkeys.html
https://www.biglumber.com
26591 .
What is an SRID code? Where does PostGIS read it from?
else?
I'm guessing now SRID is something like an EPSG code? GRASS doesn't use EPSG codes for projections; it can express them in either PROJ.4 format (used internally) or WKT (converted using the OGR library).
Paul
