[GRASSLIST:828] Getting the E00 attributes into GRASS
I'm trying to get the multiple attributes from an E00 export, but I'm not
succeeding very well in it. First, because a lot of operations are very very
time consuming (like running v.support on a copy of the vector file that has
the same name of one of the attributes). Others seem to not be working
(converting vector to raster with v.to.rast with the name of the attribute
and copying the attributes from dig_cats to cats - d.legend or r.report hangs
or at least stays consuming CPU for too long).
What would be the right, simplest and fastest way to do this?
Gualter Barbas Baptista
GAIA - Grupo de Acção e Intervenção Ambiental
http://gaia.org.pt
Witch! Witch! They'll burn ya!
    -- Hag, "Tomorrow is Yesterday", stardate unknown
I keep getting the strange problem of not being able to show the legend (d.legend) or the report (r.report) of a raster file with the attributes copied from an imported vector file (using m.in.e00, then v.to.rast, then copying dig_cats/map.attribute to cats/rastermap.attribute). This is how the file in cats looks like:
# 270016 categories
drastic.s
0.00 0.00 0.00 0.00
1:-9999
2:-9999
3:-9999
4:-9999
5:-9999
6:-9999
7:-9999
8:-9999
9:-9999
10:-9999
11:7
12:7
13:-9999
14:7
270009:-9999
270010:-9999
270011:-9999
270012:10
270013:10
270014:10
270015:10
270016:10
r.report or d.legend stay consuming CPU without any result. Suggestions?
Gualter
Gualter Barbas Baptista wrote:
I'm trying to get the multiple attributes from an E00 export, but I'm not succeeding very well in it. First, because a lot of operations are very very time consuming (like running v.support on a copy of the vector file that has the same name of one of the attributes). Others seem to not be working (converting vector to raster with v.to.rast with the name of the attribute and copying the attributes from dig_cats to cats - d.legend or r.report hangs or at least stays consuming CPU for too long).
