[GRASSLIST:829] Re: Snapping across multiple vectors?
I checked on the list archives and the last time this question was
asked was 2004, so I was wondering if snapping between two separate
vectors has been implemented? I have a series of DGPS navigation fixes
that I want to snap onto a ship trackline. Right now, the points are
just a tad offset from the lines (< 1m) and I want to make them
topologically coincident.
You can't give line nodes or vertices attributes, only change them to
points and then give those points attributes. You can only give a line
as a whole an attribute.
v.to.points [-v]
v.distance upload=to_attr,dist # works on nearest, up to "dmax"
(probably good to use v.distance upload=dist in a column then run
v.univar on result to check for any bad matches)
see example 6 on the v.distance help page: (using spearfish dataset)
http://grass.ibiblio.org/grass61/manuals/html61_user/v.distance.html
Hamish
