[GRASSLIST:8319] Editing data in GUI
What is the easiest way to edit point co-ordinates and associated data
in GUI. If I imported point using v.in.ascii, and found on displaying
resulting map, that one point need to be corrected, then can I click
that point and then change co-ordinates? I could not find such option.
Thanks in advance.
H.S.Rai
http://www.fastmail.fm - A fast, anti-spam email service.
v.digit (freezing and crashing)
QGIS Grass digit plugin
Maciek
Thanks in advance.
H.S.Rai
W polskim Internecie s? setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.epf.pl/
> data in GUI. If I imported point using v.in.ascii, and found on
> displaying resulting map, that one point need to be corrected, then
> can I click that point and then change co-ordinates? I could not
> find such option.
'd.what.vect -e' is by far the easiest way.
For me, v.digit has never been /that/ bad.. I've used it quite a bit and
only had a crash after digitizing ~600 points in one session while at
the same time displaying the same points with d.vect in a background
command. Makes me wonder if there is something with your setup that
triggers a bug that I don't see?
Hamish
find such option.
It seems Hardeep wants to move his points as well, not only edit attributes.
Then he has to use QGIS Grass digitizer or v.digit.
Maybe it is that you are on Debian and propably using tcl/tk 8.3, while I being on Mandrake have to use 8.4? But even if that's a good guess, and even if I could use 8.3, it would be no solution. Grass should adapt to new tcl/tk, not the other way round I think.
As to freezing, I recall it happens (really often), when editing or querying
attributes, as well as in v.digit as in "d.what.vect -e".
Form lib was pretty operational in 5.7. During 6.0 developement something went really wrong there (http://intevation.de/rt/webrt?serial_num=2927). A fix by Radim was applied which fixed the "broken piping", but maybe it has introduced freezing as an sideeffect? I also remember that in Mandrake 9.2 I never had problems with form lib in 5.7, while in Mandrake 10.1 same 5.7 vesions wher less stable in form GUI mode. So it might be something changed in tcl/tk between Mandrake 9.2 and 10.1 and Grass tcl/tk code doesn't take this change into account. These are just my naive gueeses.
As to crashing, it happens particulary when zooming in and out much. Which,
I suppose, it is related to the fact that v.digit changes the region
resolution during zooming. Take a look at:
http://intevation.de/rt/webrt?serial_num=3047&display=History
http://intevation.de/rt/webrt?serial_num=3164&display=History
http://intevation.de/rt/webrt?serial_num=2962&display=History
I'm affraid I won't be able to provide more details unless there is someone
willing to take care of these and needs some assistance. Because on a daily
basis I avoid v.digit for serious work, too much problems (it freezes, you
have to kill it, rebuild topology, run it once more, it freezes, ... ).
Luckily it has never damaged my data for real - I wonder if it could?
Maciek
Samoobrona lista nr. 15 www.samoobrona.org.pl
