[GRASSLIST:8331] v.in.garmin
Dear list,
I see that v.in.garmin script in GRASS 6.1.x (develop version) is broken, the
rigth script is only in GRASS 6.0.1 (stable version).
Can you exchange it?
Thanks
Leonardo
Leonardo Lami
lami@faunalia.it www.faunalia.it
Via Colombo 3 - 51010 Massa e Cozzile (PT), Italy Tel: (+39)349-1310164
GPG key @: hkp://wwwkeys.pgp.net http://www.pgp.net/wwwkeys.html
https://www.biglumber.com
broken, the rigth script is only in GRASS 6.0.1 (stable version).
I was not aware that it was broken. Can you explain what is wrong?
Probably your locale using commas for decimal places, which makes awk
choke. This should be fixed by Moritz Lennert a few hours ago, can you
update, test and report back working/not working?
From a design perspective I am surprised that the specific
(LC_NUMERIC) doesn't override the generic (LC_ALL) setting.
but,
"LC_NUMERIC
    In the absence of LC_ALL, LC_NUMERIC chooses the numeric format
locale. In the absence of both LC_ALL and LC_NUMERIC, LANG chooses the
numeric format."
If that's how it is, that's how it is.... shrug.
devels & international scripters:
I have cleaned up & sync'ed the latest changes. messy! tsk tsk. :slight_smile:
Now both 6.1-cvs and 6.0.x versions are the same, be they broken or
fixed. Untested as the GPS I usually use is in the field currently
and I'm just different versions of en_* anyway.
rather than:
unset LC_ALL
export LC_NUMERIC=C
should we just do:
export LC_ALL=C
or is it better to 'unset LC_ALL' and let LANG fill in the other blanks?
yes, just copy over the file into $GISBASE/scripts/.
I don't understand why the 6.0.1 version would work when the 6.1cvs
version didn't though.. The 6.0.1 version wasn't unsetting LC_ALL
either. Moreover I seem to remember getting a positive outcome when we
added LC_NUMERIC when this first came up. Maybe different platform
different issues.. regardless, hopefully it is working ok now.
The script WAS broken in 6.0.0.
Hamish
Hi Hamish,
Hi list,
Probably the problem was in using commas for decimal places so you said.
Now the new version works well.
Also a little error about the control on gps device is ok.
In the GRASS 6.1.x (develop version) a "-p" preceded the name of the driver
and so the driver was not known.
Thanks for the help
Best regards
Leonardo
Alle 09:31, martedì 20 settembre 2005, hai scritto:
but,
"LC_NUMERIC
numeric format."
rather than:
unset LC_ALL
export LC_NUMERIC=C
should we just do:
export LC_ALL=C
Hamish
Leonardo Lami
Hamish wrote:
rather than:
unset LC_ALL
That should be "export -n LC_ALL"; unset only unsets shell variables.
export LC_NUMERIC=C
should we just do:
export LC_ALL=C
That will override LC_MESSAGES, which we probably don't want.
Probably.
Glynn Clements wrote:
> rather than:
> unset LC_ALL
Sorry, that will work. If a variable is exported, all changes to the
variable are exported, so unsetting it will also remove the export.
