[GRASSLIST:8389] ps.map's language characters support
hello
I need to create a hard copy map with "ps.map".
But my language characters (Turkish) seems not to be supported.
Is there any way to solve the problem ?
regards
Ahmet Temiz
______________________________________
XamimeLT - installed on mailserver for domain @deprem.gov.tr
Queries to: postmaster@deprem.gov.tr
The views and opinions expressed in this e-mail message are the sender's own
and do not necessarily represent the views and the opinions of Earthquake Research Dept.
of General Directorate of Disaster Affairs.
Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
How are you trying to send them? via a comments file? the text command?
labels command?
Try via a comments file, I know extended chars like copyright symbols
work from there which won't display in some xterms. As a last resort you
might open the .ps file in a text editor, search for the text string that
does work (or some placeholder text), and replace with the text you want.
Hamish
labels command?
Hamish
thank you
I opened ps file in a text editor(gvim). Domestic characters look
ok in it. But when I open it with ggv, they look weird.
can you tell me why ?
regards
Ahmet Temiz
I had a similar problem (Latin2). I solved it manually,
ps.map -> eps(ps) -> ogonkify and then to change ISOLatin1Encoding ->
ISOLatin2Encoding (text editor)
maybe it helps?...
Martin
