I finally managed to import the E00 files I need (not the same, I had to
pick another one, with only one attribute) into a "readable" raster.
However, I have now come to another problem - I have the polygon numbers
as the category numbers and what should be the real category numbers as
the category labels (which means that, for my case of soil classes, I
have no idea about what the numbers refer to).
For example, running r.report gives the following:
|2525|10
|2527|10
|2528|10
|2529|10
|2530|-9999
|2531|6
|2533|6
|2534|10
|2535|4
|2536|4
|2537|10
I think the problem is during the import as I didn't specify any
categories to import. Is there a way to do this without linking to a
database?
Gualter
