Is there a quick way of working on a single grass module's source code,
without having to recompile the entire GRASS codebase ?
right now I am doing things like this:
in the GRASS6-cvs root folder
1. configure
2. make
3. adjust a single modules source code
4. make in the modified module's directory
---> results in a new object file
5. make from the grass root dir\
--->makes binary files
6. make install
... but this takes oh so long...
any tips?
thanks!
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
1. configure
2. make
6. make install
any tips?
thanks!
AFAIK, you shouldn't have to re-configure over and over or even recompile the whole thing. I would just go to the source directory where you are working on the code and run make there, then go to the root folder and run make install.
I haven't tried it but I think it should work.
T
Trevor Wiens
twiens@interbaun.com
The greatest obstacle to discovery is not ignorance - it is the illusion of knowledge.
(Daniel J. Boorstin)
code, without having to recompile the entire GRASS codebase ?
sure. From the INSTALL file that comes with the source code:
COMPILING INDIVIDUAL MODULES - OWN MODULES
Compiling self-made GRASS modules or modified modules:
Simply run "make" in the appropriate directory
and then install with "INST_NOW=y make".
It is not necessary to install the full distribution.
You may want to make an alias: alias gmake='INST_NOW=y make'
Personally I run grass directly out of the build dir and never install
it, so I just run "make" from the module's dir and that's enough.
