[GRASSLIST:8433] problems in gnomonic projection cont'd
Hello all,
several weeks I am struggling with reprojection from/to gnomonic projection and
I am more and more convinced that something is wrong in r.proj/v.proj dealing
with gnomonic projection.
I was trying to give you the simplest example of the problem that still persists.
Enclosed you will find two locations, rad_m and fi_lambda, both roughly for the
same region, the former in gnomonic projection and the latter in lat/lon.
In the gnomonic projection there is an artificial array with some distinct
values creating a cross at a given location (it is the reference point of the
projection but it could be any arbitrary point)
d.proj -l -d works nicely, the point/cross gives accurate values:
          EAST: NORTH: LON: LAT:
          -62.5 237.5 14.44612648 50.01013321
When using proj for the LON/LAT:
proj +proj=gnom +lat_0=50.008 +lon_0=14.447 +a=6379000 +x_0=301500 +y_0=-217500
+es=0. +no_defs -f %6.0f <<EOF
it gives
301438 -217262 which, in respect to above mentioned results of d.proj -l -d,
and the false easting/northing given by proj parameters, gives nice match.
Here it works OK.
But, when I am in location fi_lambda and want to reproject 00test map into it,
it imports well but everything is by 0.2 degree to north.
Reprojection:
r.proj input=00test location=rad_m mapset=salek output=00test method=nearest
Then, when pointing to the little point/cross:
d.where -l -d
              LON: LAT:
         14.447125 50.20371875
The latitude should be near 50.01. The little difference in LON does not bother
me, but the LAT does.
Similar results are in Spearfish area, even the difference is the same.
If you want to import the data yourself, try in rad_m:
r.in.bin input=<PATH>/input_gnom.int output=00test bytes=2 north=217500
south=-310500 east=426500 west=-301500 rows=528 cols=728
Has someone an idea why the latitude is wrong?
Best regards
Milan
    ___________
    \ o o / Milan Salek
     \ ^ / Regionalni predpovedni pracoviste
      \ ~ / Regional Forecasting Office Brno
      ( ( ) ) Czech Hydrometeorological Institute
    ( ( . ) ) Kroftova 43, 616 67 Brno, Czech Republic
(____________) ) tel.: +420-541 421 072
      //// fax : +420-541 421 018
     //// E-mail: salek@chmi.cz
                   cell phone: +420-724 185 618
http://www.chmi.cz
Ceska meteor. spolecnost / Czech Meteorological Society:
http://www.chmi.cz/poboc/BR/metspol/metspol.html
File attachment: test_of_gnomonic_error.zip
The file attached to this email was removed
because the file name is not allowed.
Sorry, the attachments are not allowed in the list. If someone is interested in
resolving of the the issue (which is definitely appreciated), ask me for the
attachment and I will send it directly to the e-mail address.
Milan Salek
Milan Salek napsal(a):
Hello all,
it gives
Here it works OK.
Reprojection:
d.where -l -d
              LON: LAT:
Best regards
Milan
