[GRASSLIST:848] Ellipsoid Shift For GRASS Vector Map
Hello all,
I have a GRASS vector map that has been converted from a toposheet.This vector map is based on the "everest" spheroid/ellipsoid.I have a few GRASS raster maps that are based on the "WGS84" ellipsoid.
I need to overlay the vector map on these raster maps.
How do i go about converting the ellipsoid of the vector map from everest to WGS84 ? What command can i use ? I am not sure if i can us the "m.datum.shift" command for this. However, if i can go ahead with "m.datum.shift", what values do i need to provide in the lat and lon parameters of the command?
any pointers ?
Vidya Kotamraju.
The way things appear to me, in that way they exist for me;
and the way things appears to you, in that way they exist for you.
                                                          -Plato
Kotamraju Vidya
Marine HydroDynamics Lab,
Physical Oceanography Division,
National Institute of Oceanography,
Dona Paula, Goa 403 004, India.
Ph.: +91-832-2456700 *4400 (O)
      +91-832-2541756 (R)
e-mail: vidyakr@darya.nio.org
Hello
As the man page for m.datum.shift says, it is an experimental program and
in fact it has been superceded by other better solutions.
You need to use the latest CVS version (now to be called GRASS
5.3.x)---the CVS snapshot from the website will do for this and v.proj is
the command you need. (You may also like to look at the PROJ.4 software
http://remotesensing.org/proj/ )
However you need to provide some datum transformation parameters for
your everest location---these would be a set of either 3 or 7 numbers. Add
a line
towgs84: dx,dy,dz
(where dx dy dz are the 3 numbers) to the PROJ_INFO file in your everest
location. You can edit the file by hand and it is quite easy to do, or
run g.setproj and select a 'custom' datum when prompted (but you need to
re-enter the other paramters for your projection if you use g.setproj).
Then as long as you also have a datum defined for the wgs84 location, just
start GRASS in that location and run v.proj to re-project the map from the
everest location.
There are some links in the datum.table and datumtransform.table files (in
the etc subdirectory under the main GRASS installation directory) that
have hints on where to find appropriate datum transformation parameters.
If you have some information on the name of the datum and the parameters
that should be used in your area, let me know so I can add them to GRASS
for the future.
Paul Kelly
Hi paul,
Thanks for the earlier response.
As mentioned earlier, I have a GRASS vector map that has been converted from a toposheet.This vector map is based on the "everest" spheroid/ellipsoid.I have a few GRASS raster maps that are based on the "WGS84" ellipsoid.
The raster maps are of 1-kilometer resolution.
I wanted to know the order of error expected by making use of an everest-based vector map on a WGS84-based raster map.
what do u expect the order of error to be in this case ?
Vidya Kotamraju.
Paul Kelly wrote:
Hello
a line
towgs84: dx,dy,dz
everest location.
for the future.
Paul Kelly
"Curiosity is one of the permanent and certain
characteristics of a rigorous intellect"
                                       - Samuel Johnson
Kotamraju Vidya
Ph.: +91-832-2450400 (O)
      +91-832-2541756 (R)
On Mon, 11 Aug 2003, Vidya Kotamraju wrote:
Hi paul,
"WGS84" ellipsoid.
I don't know; it depends on the local conditions. Usually is a shift of
the order of a few hundred metres but it might be more or less depending
on the local circumstances. If you find somebody who can answer that
question, they would probably also be in a position to provide you with
the datum shift parameters you need to do the transformation in GRASS.
