[GRASSLIST:8487] neighbourhood analysis
Hello,
I am trying to do landform analysis based on various elevational
variability charateristics. I wanted to used a circular focal point
moving window analysis. My DEM is 30m resolution. I am currently running
Grass 6.0 through Cygwin.
I have tried using r.neighbours but it seems to limit my window size to
25 pixels (750m), and what I can see only offers a square neighbourhood.
I would like to do my analysis over a 3000m area so I need a much larger
window. Is there a way to do this in GRASS without "growing" my raster
size or averaging the data prior to analysis?
Thank you,
Kessie.
Ksenia E. Konwicki, RPF
Ecologist
Timberline Forest Inventory Consultants
1579 9th Avenue
Prince George, BC V2L 3R8
P (250)562-2628
F (250)562-6942
E kes@timberline.ca
Modify r.neighbors to suit your purpose.
Or use R/GRASS or r.{in,out}.mat and Matlab/Octave.
Hello,
you can add the needed window sizes to main.c within grass6/raster/r.neighbors
just change line 94, eg:
  parm.size->options = "1,3,5,7,9,11,13,15,17,19,21,23,25,100,500" ;
and then compile r.neighbors again as described in the file INSTALL,
section "(G) COMPILING INDIVIDUAL MODULES - OWN MODULES"
-> but larger windows will result in way longer computation times.
Don't know what to do about circular moving windows, though.
Would like to give it a try myself, but didn't have time to delve into it.
cheers,
  robert
You'd probably want to make those additional window sizes odd, not even.
Very good point WRT larger window sizes.
Hamish
It's easier to just remove that line and manually check that the
window size is odd (the algorithm assumes this).
To use a circular (or other non-square) window, you would just need to
reimplement the gather() function in gather.c.
I suggest pre-creating a bitmap of the cells comprising the window
rather than computing the Euclidian distance repeatedly.
