[GRASSLIST:8516] troubleshooting Cygwin and Grass 6 installation
Dear Grass users,
Could someone help me with CYGwin and GRASS 6 installation under Windows XP? I am having a hard time to install Grass and the web tutorials seem to be of no help to overcome specifics…
When trying to restart the installation process using CYGwin setup, following the step “choose a download site” and after adding http:/geni.ath.cx/ to the list and selecting it together with another mirror site, I am getting the following error messages:
Cygwin Setup:
Can’t open http:/geni.ath.cx/grass/setup.bz2 for reading: Invalid argument
Cygwin Setup:
Unable to get setup.ini from http:/geni.ath.cx/grass
Many thanks in advance for any help. Would appreciate as well if someone has written an alternative step by step installation “guide” under Windows XP and could share it…
Paulo
I am running Grass 6.1.cvs on Cygwin/Windows XP. I once had a similar problem with the cygwin install. This was because I added only:
http://geni.ath.cx
as a download site. I should have added it as:
http://geni.ath.cx/grass
Although once the download site is added, you won't see the "/grass" part on the list. I don't know if this is the problem you are having. I didn't have to follow any special instructions to get things to work under XP.
In the past, I have also installed the Grass files manually, after installing Cygwin only. The instructions for this are under the header "Alternative installation for 6.1 CVS" on http://geni.ath.cx/grass.html. This bypasses the <http://geni.ath.cx/grass&gt; download site completely -- you just need to connect to one of the sites that has the base Cygwin files. Of course, then you'll be running the CVS version, and not the release version. But that shouldn't be a problem.
eva.
Paulo Froes wrote:
Dear Grass users,
Could someone help me with CYGwin and GRASS 6 installation under Windows XP? I am having a hard time to install Grass and the web tutorials seem to be of no help to overcome specifics...
When trying to restart the installation process using CYGwin setup, following the step "choose a download site" and after adding http:/geni.ath.cx/ to the list and selecting it together with another mirror site, I am getting the following error messages:
Cygwin Setup:
Can't open http:/geni.ath.cx/grass/setup.bz2 for reading: Invalid argument
Cygwin Setup:
Unable to get setup.ini from <http:/geni.ath.cx/grass>
Many thanks in advance for any help. Would appreciate as well if someone has written an alternative step by step installation "guide" under Windows XP and could share it...
Paulo
Eva L. Hulse
PhD Student
University at Buffalo Anthropology Department
evahulse@buffalo.edu
I found the steps on this website to be helpful when I was setting up
Cygwin/Grass 6. The website is titled "WinGrass for the Green".
http://jrshelby.com/grass/
Hope it helps.
Kessie.
Paulo Froes wrote:
Dear Grass users, Could someone help me with CYGwin and GRASS 6
specifics... When trying to restart the installation process using
another mirror site, I am getting the following error messages: Cygwin
Setup: Can't open http:/geni.ath.cx/grass/setup.bz2 for reading:
Invalid argument Cygwin Setup: Unable to get setup.ini from
Paulo
Ksenia E. Konwicki, RPF
Ecologist
Timberline Forest Inventory Consultants
1579 9th Avenue
Prince George, BC V2L 3R8
P (250)562-2628
F (250)562-6942
E kes@timberline.ca
2005/10/6, Paulo Froes <froesp@yahoo.com>:
Dear Grass users,
Paulo,
Eu não posso te ajudar com esse assunto específico.
Me lembro de ter seguido os tutoriais e tudo ter funcionado bem.
Eu pediria que você tentasse usar a versão em português e desse um parecer.
Eu sou o único tradutor do GRASS para português e ainda não tive um
retorno dos usuários. Apenas saiba que a tradução não está completa no
CVS, estão faltando uns 15% das mensagens traduzíveis.
Não sei qual o estado da tradução do pacote para cygwin.
No Referendo de 23 de outubro, vote 1.
http://www.votonao.com.br/
Dear Eva,
thanks a lot.
It seems I have installed Grass 6.1 cvs and also the 6.0 (geni/ath/cx seems to be working again!).
I even managed to start up Grass 6.1 ( and also the 6.0). But in both situations I am getting the following messages:
Warning: Invalid Database
Warning: Invalid database. Finding first valid directory in parent tree.
After OKing the warning message and trying the browse button (both versions) to set the directory where I have saved already the “spearfish57” (…/database/) I am getting the following message, no matter what:
Application error
Error: couldn’t change working directory to “./database”: no such file or directory.
Could you (or maybe some other user ) still help?
Thank you very much once again in advance for your attention and patience…
Paulo
http://geni.ath.cx
Although once the download site is added, you won’t see the “/grass”
part on the list. I don’t know if this is the problem you are having.
I didn’t have to follow any special instructions to get things to work
under XP.
“Alternative installation for 6.1 CVS” on http://geni.ath.cx/grass.html.
This bypasses the
I may not be helpful here. But I have some ideas:
1) Grass 6.1.cvs and 6.0 do not like to live together on the same machine. I have only had problems when I have had both versions installed. You might have to completely clear out your Grass installation, and start again with just one version of Grass.
2) the spearfish data should be in a folder within your home directory. For example,
C:\cygwin\home\Eva\spearfish60
You can even uncompress the spearfish_grass60data.tar.gz file using WinZip, which will create the spearfish60 directory, which you can then drag and drop into your home directory using Windows (because the Cygwin command line interface can be a mystery to us Windows users).
eva.
Paulo Froes wrote:
Dear Eva,
thanks a lot.
*Warning: Invalid Database*
After OKing the warning message and trying the browse button (both versions) to set the directory where I have saved already the "spearfish57" (.../database/) I am getting the following message, no matter what:
*Application error*
Error: couldn't change working directory to "./database": no such file or directory.
Thank you very much once again in advance for your attention and patience...
Paulo
    http://geni.ath.cx
    under XP.
    This bypasses the download site completely
    Cygwin
    files. Of course, the n you'll be running the CVS version, and not the
    eva.
    Paulo Froes wrote:
     > Dear Grass users,
     > Could someone help me with CYGwin and GRASS 6 installation under
    Windows
     > XP? I am having a hard time to install Grass and the web
    tutorials seem
     > to be of no help to overcome specifics...
     > When trying to restart the installation process using CYGwin setup,
     > following the step "choose a download site" and after adding
     > http:/geni.ath.cx/ to the list and selecting it together with
    another
     > mirror site, I am getting the following error messages:
     > Cygwin Setup:
     > Can't open http:/geni.ath.cx/grass/setup.bz2 for reading: Invalid
    argument
     > Cygwin Setup:
     > Unable to get setup.ini from
     > Many thanks in advance for any help. Would appreciate as well if
     > someone has written an alternative step by step installation "guide"
     > under Windows XP and could share it...
     > Paulo
    Eva L. Hulse
    PhD Student
Eva L. Hulse
PhD Student
hi,
For example,
eva.
you should follow the white rabbit -- http://www.gdf-hannover.de/media.php?id=7&lg=en in this case
it is always better to create your GRASS Database directory in your home
direcotry, the spearfish60 directory should go into "grassdata"
directory in your HOME directory:
$ mkdir grassdata
$ cd grassdata
$ tar -xvzf /where/ever/you/have/spearfish_grass60data.tar.gz
$ cd ..
$ grass61
results into
C:\cygwin\home\Eva\grassdata\spearfish60
Jachym
P.S. Otto, why there are on PDFs on the Translation portal?
Paulo Froes wrote:
>Dear Eva,
>thanks a lot.
>no matter what:
>*Application error*
>or directory.
>patience...
>Paulo
> http://geni.ath.cx
> under XP.
> Cygwin
> eva.
> Paulo Froes wrote:
> > Dear Grass users,
> Windows
> tutorials seem
> another
> > Cygwin Setup:
> argument
> > Cygwin Setup:
> > Paulo
> Eva L. Hulse
> PhD Student
Eva L. Hulse
PhD Student
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/
OFFICE:
Department of Geoinformation Technologies
LDF MZLU v Brnì
Zemìdìlská 3
613 00 Brno
e-mail: xcepicky@node.mendelu.cz
URL: http://mapserver.mendelu.cz
Tel.: +420 545 134 514
