[GRASSLIST:8554] Mandriva LE2005 : NVIZ error
Dear all,
I've installed grass6.0.1. If I try to start NVIZ, following error will raise :
Loading required GL library /usr/X11R6/lib/libGL.so.1.2
libGL warning: 3D driver claims to not support visual 0x24
libGL warning: 3D driver claims to not support visual 0x28
libGL warning: 3D driver claims to not support visual 0x2c
libGL warning: 3D driver claims to not support visual 0x30
Please, what to do now ?
Thank you
Peter
On Sun, Oct 09, 2005 at 02:48:05AM +0200, Ing.Peter Misovic wrote:
Dear all,
Thank you
Peter,
I don't know if anyone answered, but you can simply ignore
it (AFAIK). It's just a warning, I have it, too.
Hi Markus,
problem is that NVIZ is not running. Only those messages are displayed
and that's all. :frowning: But as I wrote, I installed newer libMesa packages
and everything is OK now. The most interesting for me is that 6.0.1RC2
was running with any problem. Was GRASS built on newer versions ?
Anyway, thank you for your response.
> Dear all,
> Thank you
Peter,
