Hello,
I used r.fragstats a few weeks ago without any problems but now I receive the
error prompt: ERROR! Can not allocate space for edgetype! (see below the full
message)
For testing purpose, I used various raster as input and considered as well
the null() values problem but with all raster files the same error message
appears.
Might it be due to a newer GRASS cvs Version because I updated in the
meanwhile my GRASS cvs and recompiled it? Perhaps somebody encountered the
same problem and can give me a hint how to solve this problem.
thanks in advance, Martin
Using debian sarge, GRASS cvs 11.10.05 and r.fragstats from Jachyms GRASS
add-on page (http://www.fle.czu.cz/~jachym/programs/grass.html)
g.gisenv set="DEBUG=5"
r.fragstats input=test_ML output=test_out background=3 bound_wght=0.0 -i
FRAGSTATS 2.0
PROGRAM TO CALCULATE LANDSCAPE FRAGMENTATION INDICES
Processing image: test_ML
rows: 0
Interior Background Value: 3
Exterior Background Value: -3
maxclasses: 0 rows:
number of classes: 0
max patches/class: 0
max patch size: 0
ERROR! Can not allocate space for edgetype!GRASS 6.1.cvs
r.info test_ML
| Layer: test_ML Date: Wed Oct 12 16:47:57 2005
| Mapset: test1005 Login of Creator: Martin
| DataBase: /data1/grassdb
| Title: Maximum Likelihood Classification ( test_ML )
| Type of Map: raster Number of Categories: 46
| Data Type: CELL
| Rows: 680
| Columns: 1187
| Total Cells: 807160
| Projection: Latitude-Longitude (zone 0)
| N: 9:58:29.185189N S: 4:14:47.55737N Res: 0:00:30.325923
| E: 0:00:30.162962W W: 10:00:27.033876W Res: 0:00:30.325923
| Range of data: min = 2 max = 46
| Data Source:
| Group/subgroup: test/test_sub
| Signature file: test_sig
| Data Description:
| generated by i.maxlik
