[GRASSLIST:8593] newbie question region
Hi all I'm very new to GRASS and just trying to figure a few things out, I
have some experiance with GIS and have done a few of the online tutorials
using Spearfish. I would like to now try to use some of my own datasets
(mostly in ESRI shpfiles or GTiffs)but am having trouble setting up my
environment (Database location mapset g.region etc..) I've tried setting up
a empty database and using import GDAL some of my DEM GTiffs but am unable
to set the region (I tried the raster extents as north south east west
limits). Basically I'm looking for advice on how to set up a empty database
and then on how to import data into it.
Travis
On Wed, 12 Oct 2005 16:29:18 -0400
Travis
I assume you are using GRASS 6.0. What I've done in the past (I haven't setup anything new in a while) is to determine the projection I needed and made the region smaller than I needed, the used r.in.gdal or v.in.ogr and set the option to extend region extents based on the input file (thus the first file I would pull would be something that would cover the entire area like a jurisdictional boundary, etc.).
T
Trevor Wiens
twiens@interbaun.com
The greatest obstacle to discovery is not ignorance - it is the illusion of knowledge.
(Daniel J. Boorstin)
out, I have some experiance with GIS and have done a few of the online
tutorials using Spearfish. I would like to now try to use some of my
own datasets (mostly in ESRI shpfiles or GTiffs)but am having trouble
setting up my environment (Database location mapset g.region etc..)
I've tried setting up a empty database and using import GDAL some of
my DEM GTiffs but am unable to set the region (I tried the raster
extents as north south east west limits). Basically I'm looking for
advice on how to set up a empty database and then on how to import
data into it. Travis
some tutorials list here:
http://bambi.otago.ac.nz/hamish/grass/
  and here
http://grass.ibiblio.org/gdp/tutorials.php
make the region anything at setup, and then after importing use
g.region rast=your_map
to zoom to the extent of you imported map. The default region will be
wrong, but that's ok.
also you can use "gdalinfo yourfile.tif" etc to find the extents of your
map before setting up a location or create a simple XY location and use
r.in.gdal's "location" option to create a new location from the
projection info stored in your data file. Then exit GRASS and restart in
the newly created location.
good luck,
Hamish
