[GRASSLIST:8601] Recommended OS
hello GRASS community!
I am planning to implement GRASS on a workstation, but I can't decide if I
should use Linux/Fedora or MacOS on a PowerMac. Can anybody recommend
something? I have some UNIX experience in the distant past, but do not have
experience with either of these OS's.
Dave Van Vliet (Guelph, Ontario, Canada)
David Van Vliet, M.A.Sc., P.Eng.
AquaResource Inc.
Ph: (519) 489-4585 (Canada)
Ph: (267) 765-5644 (US)
Fax: (519) 699-4982
Web: http://www.AquaResource.ca
eMail: dvanvliet@AquaResource.ca
The contents of this email and any attached files are confidential and
intended solely for the use of the individual to whom they are addressed.
If you are not the intended recipient, please delete all copies and notify
AquaResource Inc. immediately.
have experience with either of these OS's.
AquaResource Inc.
Fax: (519) 699-4982
If you are a beginner, i'll tell you to try www.ubuntu.com...
Greetings
Luca
I videogame non influenzano i bambini: infatti se da piccoli fossimo
stati plagiati da Pac-man, adesso passeremo il nostro tempo in
ambienti
semibui, mangiando pillole magiche, ed ascoltando della musica elettronica
ripetitiva.
Kristian Wilson, Nintendo Inc., 1989
skype : thedoktor78
msn: doktoreas@hush.com
Ι do not want to start OS wars here... Just an opinion
Since you say you had "some UNIX experience in the distant past", stick to MacOS X (especially since you already have the Powermac). If you did not have the PowerMac already, and you owned a x86 box, then my answer may was different (because of the extra cost).
Kostas
AquaResource Inc.
Fax: (519) 699-4982
Hello,
Well, my suggestion is any Debian based distro (including Debian of course!). BTW: Attention: Ubuntu is not following Debian anymore, so it’s not very compatible.
Debian (the original) may be not so easy do install. But using the DebianGIS repository is very easy to install/upgrade GRASS (and other related softwares like QGIS).
http://pkg-grass.alioth.debian.org/cgi-bin/wiki.pl
Also, using Debian’s Apt-Get or Synaptic is very easy to install dependencies for compile GRASS from the source code.
So, try to use a Linux distro that have a internet option install/upgrade to GRASS. In my opinion is the better choice for newbies.
Feel free to write directly for some help.
Christian dos Santos Ferreira
Oceanographer. Msc.
Lab. of Fisheries Research and Hydroacustics
Federal University of Rio Grande (FURG)
Rio Grande - RS - Brazil
Tel +55 (53) 32336528
Website: http://poseidon.furg.br
David,
I've been using GRASS on a Mac for a couple years now, and just set up a
Fedora Core 4 Linux workstation with GRASS in my research lab. The Mac OS
(current is OS X 10.4) is based on BSD Unix now, so there is considerable
similarity 'under the hood' of both systems.
The way GRASS 6.x is currently, my feeling is that GRASS binaries
(maintained by Lorenzo Moretti) are easier to install on a Mac OS than any
other platform currently supported by GRASS.
From admittedly limited experience, it seems that GRASS is somewhat easier
to compile from source under Linux--especially Fedora/Redhat or Debian
(these seem best supported by the GRASS community at present).
When operational, I can see no difference whatsoever between the
functionality of GRASS on Mac OS X and Linux. I think file management and
networking is somewhat easier on a Mac--but that may be because I'm more
used to it.
Currently, GRASS on Windows XP is a little slower (but not obviously much)
than either Mac or Linux platforms due to the requirement of running under
the Cygwin emulator. It is also more difficult to compile and the binaries
are more complicated to install (though MUCH helped by Cygwin/Windows binary
maintainer Huidae Cho's very nice www installer).
Hope this is helpful.
Michael
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
From: "David Van Vliet (personal)" <dvanvliet@gto.net>
Date: Thu, 13 Oct 2005 08:20:47 -0400
To: <GRASSLIST@baylor.edu>
Subject: [GRASSLIST:8601] Recommended OS
AquaResource Inc.
Fax: (519) 699-4982
