Anybody using Grass5 with Mapserver? I'm hoping to display "street maps"
in a browser window. I have purchased the "Grass approach" book, but it's
going to take 15days to get here, which is 14 days to long
I am.
My application uses GRASS to perform raster (r.mapcalc) calculations
with user inputs to create species suitability 'maps' that are based on
climate and soil conditions.
Check it out at http://mistral.coas.oregonstate.edu/forages
I'm very impressed with mapserver. In fact, I used to have this web
application running in ArcIMS but got so frustrated with it that I
ported it to mapserver and I'm MUCH PLEASED!!! You will be too.
Matt
(RedHat8.0, Apache2.0, Mapserver 3.7, Php4.2.3, Grass5.0)
-----Original Message-----
From: owner-GRASSLIST@baylor.edu [mailto:owner-GRASSLIST@baylor.edu] On
Behalf Of Bruce Bushby
Sent: Tuesday, July 29, 2003 10:44 PM
To: GRASS mail list
Subject: [GRASSLIST:861] Grass5 and Mapserver
it's
Google says:
http://pinus.chinju.ac.kr/grass/start.html
How can I suppress shell std output using G_system()?
maybe ...
G_system("r.mapcalc >> temp.txt")
.... but it doesn't seems to me to be enough just redirect it.
Suggestions?
Thanks you all.
Massimiliano
> going to take 15days to get here, which is 14 days to longGoogle says:
Right now I have updated the related GRASS 5.1 tutorial:
http://grass.itc.it/grass51/tutorial/ex_complex.htm
Markus Neteler
maybe ...
The above appends stdout to the file, but it leaves stderr untouched
(i.e. it's probably going to the terminal). Try:
G_system("r.mapcalc >> temp.txt 2>&1");
There are many possibilities for setting up the standard descriptors;
they will be described in the manpage for the shell, e.g. bash.
Although, if you want portability, and have "ash" installed, refer to
the manpage for ash rather than the one for bash, as bash has many
extensions which don't work with other shells.
> Google says:
> http://pinus.chinju.ac.kr/grass/start.htmlRight now I have updated the related GRASS 5.1 tutorial:
...a typo, sorry:
http://grass.itc.it/grass51/tutorial/ex_complex.html
is the correct address.
Markus Neteler
