[GRASSLIST:8621] Warning in i.rectify
Hello!
When I start i.rectify i get this error: "G_set_window(): Illegal latitude for North"
Analyze in i.points is in attach.
Can anyone know reason for this warning??
Josip Vrlic
(attachments)
kntrlTockeMK12.txt (1.13 KB)
Hello,
I'm looking for the function v.parallel which is described in the online help (but without further details) und which I can't find in my distribution (GRASS 6.0.0)?
Can anyone help?
Regards
Tim Semmelhaack
Hello Tim,
On Fri, 14 Oct 2005 14:27:29 +0200 Tim Semmelhaack
<t.semmelhaack@hamburg-consult.de> wrote:
Hello,
Can anyone help?
Have you checked the porting-list on the wiki?
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/ModulePortingList#Vector_modules
currently it is not on the list. To which GRASS-version are you
refering?
Best
  Stephan
GDF Hannover - Solutions for spatial data analysis and remote sensing
Hannover Office - Mengendamm 16d - D-30177 Hannover
Internet: www.gdf-hannover.de - Email: holl@gdf-hannover.de
Phone : ++49-(0)511.39088507 - Fax: ++49-(0)511.39088508
Tim, this might only be available in 6.1.
G'luck
-Ian
On Oct 14, 2005, at 5:27 AM, Tim Semmelhaack wrote:
Hello,
Can anyone help?
Regards
Tim Semmelhaack
What happens if a big asteroid hits Earth? Judging from realistic simulations involving a sledge hammer and a common laboratory frog, we can assume it will be pretty bad.
  - Dave Barry
This message has been scanned by Postini anti-virus software.
Hello Stephan,
I found it in the online help.
http://grass.itc.it/grass61/manuals/html61_user/v.parallel.html
But probably it's a new module in 6.1.
Tim
Stephan Holl wrote:
Hello Tim,
Hello,
Can anyone help?
refering?
Best
  Stephan
Mit freundlichen Grüßen
Tim Semmelhaack
Hamburg-Consult GmbH
Spohrstraße 6
22083 Hamburg
Tel.: 040/27166-546
Fax.: 040/27166-410
Mobil: 0163 2716 546
email: t.semmelhaack@hamburg-consult.de
Durchwahl Hamburg-Consult: 040/27166 - 500
Besuchen Sie unsere Website: www.hamburg-consult.de ,
jetzt in neuem Design und mit noch mehr Informationen.
On Fri, 14 Oct 2005 10:41:23 +0200
Josip Vrliæ <josip.vrlic@plovput.hr> wrote:
Hello!
               Analysis of control point registration
        error image target
  # col row target east north east north
  1 not used 203.3 1377.9 502575.6 4889489.7
  2 not used 627.3 1479.0 504452.9 4889940.4
  3 not used 1495.6 2921.8 508293.6 4896353.8
  4 not used 2437.4 1932.3 512411.3 4891919.2
  5 not used 3460.9 806.8 517014.0 4887008.4
  6 not used 1547.2 667.5 508476.9 4886392.9
  7 2.1 -1.5 11.1 203.9 1377.3 502948.8 4889490.0
  8 3.2 -3.8 21.8 626.9 1481.0 504825.9 4889940.5
  9 2.1 4.6 22.7 1494.5 2924.8 508666.4 4896354.5
10 -9.6 -9.1 58.3 2438.2 1931.8 512784.3 4891920.0
11 7.2 1.1 32.6 3463.1 806.8 517387.3 4887009.5
12 -6.1 6.2 38.3 1546.8 665.5 508850.2 4886393.5
13 1.1 2.4 11.7 1821.8 2714.8 510108.5 4895420.5
Overall rms error: 32.04
Are you are using a lat-lon location for your import image when you
should use a simple XY location?
The northing in a lat-lon location can not be greater than 90N; and
image north above goes up to 3464.9 degrees N.
Hamish
>>Can anyone help?
This is correct.
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/vector/v.parallel/
Hamish
