Exposing my problem : i must rear a map multilayers in Grass,for
strength dial i must do does the stop at edict v.db.addtable.
In the version by myself install , Debian , this command not it is
present ,
in order to make available it,i must update the package containing does
the command?
present ,
does the command?
It is new and not in GRASS 6.0. But v.db.addtable only does this:
present ,
does the command?
