[GRASSLIST:8634] connecting points with lines
I think this is an easy question, but I can’t seem to readily find the answer in the documentation. Is there a simple way to connect lines (create topology) in a rater point layer? Say, for example, a vector layer with two points, A and B. Is there a simple way to have GRASS connect the two with a line from A to B? Displaying this vector layer would then show a line, rather than just the two points. I need to do this from the command line, as it is part of a script.
Thanks!
  • Jason
Jason Horn
Boston University Department of Biology
5 Cumington Street Boston, MA 02215
jhorn@bu.edu
office: 617 353 6987
cell: 401 588 2766
are you working with network analysis?
v.net.path would not solve your problem?
Jachym
On Fri, Oct 14, 2005 at 01:43:58PM -0400, Jason Horn wrote:
   I think this is an easy question, but I can't seem to readily find the
   Thanks!
   - Jason
   Jason Horn
   [1]jhorn@bu.edu
   cell: 401 588 2766
References
   Visible links
   1. mailto:jhorn@bu.edu
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://les-ejk.cz/gnupg_public_key/
OFFICE:
Department of Geoinformation Technologies
LDF MZLU v Brnì
Zemìdìlská 3
613 00 Brno
e-mail: xcepicky@node.mendelu.cz
URL: http://mapserver.mendelu.cz
Tel.: +420 545 134 514
script.
r.in.poly
Hamish
