[GRASSLIST:868] Re: r,stats(In GRASSLinks)
Thank you for your adivise, SWlab.
r.stats -aql fs="^" input=$GRASTER1,$GRASTER2 > $TMP_PATH/stats.$$
> sh: line 1: cd: HOME not set
> WARNING: can't read range file for [landuse in PERMANENT]
> ERROR: r.stats: can't read range for [landuse]
> Why Can't r.stats open range file?
because HOME is not set ? Check the state of the variable.
I tried to write in /*/grasslinks/prog/reporter as follows.
HOME=/home/grass/grasslinks
But there is still a messeage in Apache error log.
1) When does "r.stats" demand variable "HOME"?
2) Where do I write variable "HOME" to let "r.stats" work?
Please give me suggestion.
Thank you in advance.
Sincerely yours.
e$BNSe(B e$B??0lO:e(B <forest@bres.tsukuba.ac.jp>
e$BC^GHBg3X@8L?4D6-2J3X8&5f2J@8J*7w;q8;2J3X@l96e(B
e$BN.0h4IM}8&5f<<e(B e$B@8G@Eoe(BE104e$B!!e(BTel&Fax 0298-53-4897e$B!!e(B
e$B@8J*;q8;4D6->pJs%7%9%F%`e(B(bres) e$B%7%9%F%`%9%?%C%U!!!!e(B
  http://ryuiki.agbi.tsukuba.ac.jp/~forest
