[GRASSLIST:872] r.terraflow compile error
Dear List
We're still can't compile r.terraflow. Below is a summary of our
compile. Any ideas anybody?
Many thanks
Ian Allan
# How-to make Grass 5.0.2
# /usr/local/grass5.0.2/src.contrib/DUKE
cd /usr/local/grass5.0.2
./configure --without-odbc --without-postgres --without-fftw --with-cxx
make pre-compile
make 2>&1 | tee make.log
cd /usr/local/grass5.0.2/src.contrib/DUKE/r.terraflow
gmake5 -i
# fails with:
# g++ -c -I/usr/local/grass5.0.2/src/include -g -O2 -Wall
# -I./IOStream/include -DUSER=\"root\" -DNODATA_FIX
-D_FILE_OFFSET_BITS=64
# -DELEV_FLOAT main.cc -o OBJ.i686-pc-linux-gnu/FLOAT/main.o
Ian,
I have successfully compiled r.terraflow several times on Mandrake. If you need a binary I can send it. Just let me know off the list.
If you need to compile the module then make sure that you have installed all red hat packages (rpms) needed by r.terraflow. The error message below doesn't say too much so I can't figure out the problem.
Jaro
Ian Allan wrote:
Dear List
Many thanks
Ian Allan
make pre-compile
gmake5 -i
# fails with:
