Ravi,
It sounds like this is a d.rast problem and not a TclTk problem. I don’t have a version of GRASS 6.1 later than 15 October on my PowerBook at home. But we have a 20 October version on the Fedora Core 4 Linux workstation in my lab and d.rast works fine. I don’t know much about the C modules, so it is better if you report it to the general list
You need to report the error you have with d.rast in detail. You can use the bug report web page if you’d like.
List the terminal output results from d.rast. Also describe the platform you are working on (OS, hardware, etc.).
With respect to the new features of the GIS Manager, look at the help page (under the help menu). I recently updated it to cover the current functions of the GIS Manager. I hope this is helpful. Let me know if you run into a specific question about it.
Michael
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
Date: Sat, 22 Oct 2005 23:21:03 -0700 (PDT)
To: Michael Barton michael.barton@asu.edu, grasslist@baylor.edu
Subject: Re: [GRASSLIST:8733] Re: GRASS 15th October CVS Bugs
the TclTk bug is not found in the earlier GRASS6.1 CVS (older than 15th Oct).
Iam just using Elevation.dem of Spearfish data for a display.
d.rast doesnt work… gives error
even in the D.M it gives the same error, when I try to displa raster.
I have used the latest D.M with the older GRASS6.1 (older than 15th Oct)
It works, BUT… NVIZ is not understood…
Please give some help about various new itmems.
The button created for attribute information, is welcome.
This will be of great use, if it can help in choosing attributes in query, istead of the user typing
the attribute names.
ThanX
Ravi Kumar
Michael Barton michael.barton@asu.edu wrote:
I have only tested the new GIS Manager (i.e., from cvs or my website) with GRASS 6.1. However, it should work with 6.0.1 except for new commands or command options that are not available in the older release.
The commands in the raster display panel include d.rast, d.legend, and d.his. All are present in 6.0.1 and haven’t changed since that release.
Are you doing a simple raster display (no draping or legend)? Does it work if you start d.rast from the command line and try to display the map? If you look at the TclTk error, it usually does give useful information, just a bit hard to find in the long error output (the most useful info is usually near the top of the error description).
Michael
phone: 480-965-6213
fax: 480-965-7671
Date: Fri, 21 Oct 2005 00:14:19 -0700 (PDT)
To: grasslist@baylor.edu
Subject: [GRASSLIST:8727] GRASS 15th October CVS Bugs
Hi All,
- I have loaded GRASS6.0.1 from CVS.
- I have also loaded the latest DM removing the old one
BUT
Unable to display raster ‘elevation.dem’ of spearfish data.
ERROR= Error in Tcl Script
Error: Child killed : Segmentation Violation
Please give details of latest DM and its function, or a web page link.
Hope it will soon be integrated with the next week’s GRASS CVS.
ThanX
Ravi Kumar
Yahoo! FareChase - Search multiple travel sites in one click. http://us.lrd.yahoo.com/_ylc=X3oDMTFqODRtdXQ4BF9TAzMyOTc1MDIEX3MDOTY2ODgxNjkEcG9zAzEEc2VjA21haWwtZm9vdGVyBHNsawNmYw--/SIG=110oav78o/**http%3A//farechase.yahoo.com/
