[GRASSLIST:8742] gmtg
Dear all, dear Jaime,
I have finaly enougth time for starting to try the use of modflow using
the grass module...
looking at the mailing list I have seen there have been some problems
with the installation reported by other users...
could you say if the problem are now solved???
can I use the tutorial at the web page
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/JaimeCarrera ?
thank you very much for your answer!!!
Ivan
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini@unipg.it
        ivan.marchesini@gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
Dear Ivan,
Yes, you can use the tutorial and the files that are
on the GMTG web page. Keep in mind that the MODFLOW
version available on this web-page is required as I
did a slight change to the code so it can run with
GMTG.
I'll be glad to know how it worked.
Jaime
the grass module...
been some problems
Ivan
Ivan Marchesini
Via G. Duranti 93/a
06125
Perugia (Italy)
__________________________________________________
Correo Yahoo!
Espacio para todos tus mensajes, antivirus y antispam ¡gratis!
Regístrate ya - http://correo.espanol.yahoo.com/
Dear Jaime...
I have succesfully installed r.gmtg ... I think... the command is now
present at the grass prompt...
and also modflow96... (also if I have tried to run the ./test 1 1 but I
have stopped because it takes a long time to run...)
Later I have created a DATAGRASS54 and copied inside the exercise1
location...
I can correcly seen the maps in the PERMANENT mapset and I can plot
them...
later I have done
cd exercise1
tar -xvf read_mflw.tar
g77 rheads.f -o rheads
g77 rddown.f -o rddown
later I have read the first part of the tutorial and I have seen that
the results of the first simulation are already present in the
location...
so I have tried to run the transient simulation using:
____________________________________________________________________
r.gmtg simulation=0 units=4 layers=1 aqtype=1 stress=2 length=240,120
steps=12,6 tsmult=1,1 region=boundaries heads=hd.lay1.stp1.tst1
K=H.conductivity Sy=Sy bottom=bottom recharge=rch.1,rch.2
wells=wells,cst.flux drawdownin=ddtr headsin=hdtr
the problem is that I don't obtain the maps
ddtr.lay1.etc
hdtr.lay1.etc
and the standard output of the command is:
Processing BAS file
  96%
       Processing BCF file
  96%
       Processing RCH file
  96%
       Processing WEL file
  Running MODFLOW
GRASS:~ > Importing DRAWDOWN
and after this there aren't active processes in my pc!!!
can you help me to understand what is happening???
it is a simple problem??? I have done a stupid question??
thank you very much!!!!
ivan
Il giorno lun, 24-10-2005 alle 10:47 -0500, Jaime Carrera ha scritto:
Dear Ivan,
GMTG.
Jaime
> the grass module...
> been some problems
> Ivan
> Ivan Marchesini
> Via G. Duranti 93/a
> 06125
> Perugia (Italy)
Correo Yahoo!
Ivan Marchesini
Via G. Duranti 93/a
06125
Perugia (Italy)
