[GRASSLIST:8745] r.fillnulls and res < 1
Hi listers,
I am having trouble with r.fillnulls and a raster having a resolution of 0.48.
Is it right that r.fillnulls only works for raster with a resolution > 1?
Does the use of r.fillnulls only make sense with rasters having a
whole-numbered resolution?
I am no expert, but the result from line 129 and 130 are integers and the
calculation in line 131 is done by the shell, which knows only integer.
How could I get sed to read the digits of my resolution?
What is the recommended way to get also the digits in line 131 (bc, awk,..)?
cheers,
  robert
Hi Robert,
thanks for finding the problem. I have fixed it in 6.1-CVS and
6.0-CVS (for future 6.0.2).
You can grab it also at
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/scripts/r.fillnulls/
Now resolution of 0.48 are accepted as well.
On Mon, Oct 24, 2005 at 07:04:53PM +0200, Robert Nuske wrote:
Hi listers,
cheers,
  robert
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
