[GRASSLIST:8748] Qgis Gps interface
I have Qgis 7 installed om MS Windows XP.
I have a Garmi Etrex GPS ( shown in Qgis as figure)
Any help to
GPS settings: Any differen Baud rate etc to be set on GPS
Windows XP settings: If any are needed
  1. Importing data from GPS to Computer
  2. Exporting to GPS
  3. Live recording from GPS on vector
    Ex: I drive through a road and the ROAD to be etched through the GPS on Map
I have already connected the Garmin GPS to 9 pin serial port, but it failed to
communicate, Import data from GPS
ThanX in anticipation
Ravi Kumar
Yahoo! FareChase - Search multiple travel sites in one click.
Any help to
2. Exporting to GPS
    GPS on Map
failed to communicate, Import data from GPS
a) you may get better answers about QGIS on the QGIS forums:
  http://community.qgis.org/index.php?option=com_simpleboard&Itemid=41
b) try GPStrackmaker Pro (not open source, but no cost) for windows
  http://www.gpstm.com
c) try gpsbable for windows, mac, or linux
  http://www.gpsbabel.org
d) gpsd for linux is the most robust general solution
  http://gpsd.berlios.de
e) try gpstrans for linux (garmin protocol only but useful)
  http://gpstrans.sourceforge.net
f) my m.realtime_gps hack(s) for GRASS 5 (uses gpsd):
  http://grass.itc.it/pipermail/grassuser/2004-February/024763.html
Often it is good enough and easier to have the GPS record its position
every 15-30 seconds and download the track to a laptop every few hours.
The setup menu for this should be found in the track display on your
Garmin.
Hamish
