[GRASSLIST:8758] Icon on raster
Dear list,
I'm using Grass 6 in the development of a cellphone network planning tool. I
would like to plan a network by setting up some cellphone towers, and would like
to know if there is some function in Grass which will enable me to place small
'tower'-icons on a raster map at specific geopoints. I am using r.what to
retrieve the location where a tower was set up, but would like to display all
the towers already set up as well.
Kobus
tool. I would like to plan a network by setting up some cellphone
towers, and would like to know if there is some function in Grass
which will enable me to place small 'tower'-icons on a raster map at
specific geopoints. I am using r.what to retrieve the location where
a tower was set up, but would like to display all the towers already
set up as well.
Make the tower possitions as vector points (v.in.ascii) then display
with "d.vect icon=your/tower". For hard copies you've got a bit more
control with ps.map, eg you can use a EPS file for the icon and
dynamically set the size with vpoints sizecol.
You'll have to make your own tower icon of course, it's not so hard to
do:
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassProgrammingHowto#Display_Symbols
move the file into $GISBASE/etc/symbol/local/tower or somewhere like
that.
It works really well.
Also check out "d.vect display=attr", v.label and d.paint.labels for
attaching tags.
Hamish
Thanks a lot Hamish,
It works perfectly.
Kobus
Quoting Hamish <hamish_nospam@yahoo.com>:
where
> set up as well.
do:
that.
attaching tags.
Hamish
> > planning tool. I would like to plan a network by setting up some
> > cellphone towers, and would like to know if there is some function
> > in Grass which will enable me to place small 'tower'-icons on a
> > raster map at specific geopoints. I am using r.what to retrieve
> > all the towers already set up as well.
> to do:
> that.
It works perfectly.
great.
I should add that if you are really proud of your homebrew symbol by all
means share it with the list for others to try &/or for possible
inclusion in future releases in GRASS.
Hamish
