[GRASSLIST:8826] DBMI-DBF driver error:
I'm new to GRASS and have just tried to shift my Grass folders to a
network drive.
I'm getting lots of dbf errors. In particular:
Cannot open dbf database: cygdrive/u/r&ddel/.../permanent/dbf/
db.connect -p returns:
driver: dbf
schema: (null)
group: (null)
The network path has a "&" symbol in one of the directory names would
this be causing the problem? (windows network, Cygwin grass (6.0)
install)
Regards
Jarl
********************************DISCLAIMER****************************
The information contained in the above e-mail message or messages
(which includes any attachments) is confidential and may be legally
privileged. It is intended only for the use of the person or entity
to which it is addressed. If you are not the addressee any form of
disclosure, copying, modification, distribution or any action taken
or omitted in reliance on the information is unauthorised. Opinions
contained in the message(s) do not necessarily reflect the opinions
of the Queensland Government and its authorities. If you received
this communication in error, please notify the sender immediately and
delete it from your computer system network.
