[GRASSLIST:886] RE: GRASS on Mac OS X
I'm no pro at grass, but I've used & installed it a number of
times with OS X and Apple's X11, without going through all
the fussing with environment variables. Have you tried
starting GRASS in text-only mode. At the prompt (e.g. "nick%")
type "grass5 -text" This will put you in text-only mode. You
have to do this to create a new location, I believe. Type the
name of the location you want to create, and if it doesn't
already exist, grass will create it. Then you can quit grass and
start again in GUI mode: "grass5 -tcltk" I believe.
The g.region dialog being larger than your screen is a bitch;
I've had it on my powerbook as well. Try hitting the green
maximize button at the top of the window; this will squish the
window down so it fits your monitor, although then the lines
may be too small to type in. But if you are going to do a lot of
work in grass, you'll be happier if you get a larger monitor.
Another option, which I like, is to use afterstep (binary
available free on the web at afterstep.org, I believe). This is an
alternative x-window manager, which by default gives you
something like 4 or 6 virtual screens: when you move the
mouse to the bottom of the screen, you pop into another
screen, with the lower part of your g.region window on it. But
you have to kill the quartz-wm process, and then start
afterstep:
ps -aux | grep quartz
returns
nick 933 0.0 0.3 80816 1560 ?? S 10:24PM 0:00.16
quartz-wm
nick 1029 0.0 0.1 1416 308 std S+ 10:33PM
0:00.00 grep quartz
where 933 is the process running the quartz window manager
(quartz-wm)
then
kill -9 933; afterstep&
will kill the quartz window manager and start the afterstep
window manager. But this is not for everybody. The bigger
monitor is really the better solution.
Nick Cahill
