[GRASSLIST:8916] points in area
is it possible to get all vektor points lying in an area? Or to greate a new map with them.
I can't find a module.
Greetings Maik
I think my question is not clear enough.
I know there's possibility to get points lying in an area with v.select.
In my map i've got several areas. I need all points lying in area a to make a statistic with v.univar. But with v.select there is only the possibility to get all points lying in all areas. That's not what I need.
Can anybody help me?
Greetings
Maik Trömel wrote:
Greetings Maik
Simply first extract area 'a' with v.extract, then run v.select on this
new map.
For several areas it's best to write a small script which loops over the
area map,
extracts, selects, and runs v.univer.
hope this helps
I thought of this too. But I hoped there would be a better solution.
new map.
area map,
hope this helps
Maik,
please define "better solution"...
>new map.
>area map,
>hope this helps
>Markus
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
I thought of a faster solution ;-p
Are there any other statistic tools like r.univar. One which is able to make a selection? Something like: "Make a statistik of all points lying in area "a"!" (without extracting and selecting before)
Maik
Maik,
new map.
area map,
hope this helps
OK, I have added a 'where' option to v.univar:
Spearfish example:
v.univar fields col=cat where='cat>10 AND cat < 20'
WARNING: Incompatible vector type(s), only number of features, minimum,
         maximum and range can be calculated
number of features with non NULL attribute: 18
number of missing attributes: 108
number of NULL attributes: 0
minimum: 11
maximum: 19
range: 8
Using the new v.what.vect script (submitted this morning) you could add
a new column "areacat" to the points map and upload the area categories (IDs)
to the points map. Then use the modified v.univar and select only the
area of interest.
Sounds better?
Maik
>Maik,
>Markus
>>>>need.
>>>new map.
>>>area map,
>>>hope this helps
>>>Markus
