[GRASSLIST:892] Re: Problems importing a GMT grd file (SOLUTION)
This is a wrap-up to a problem I had importing GMT grd files into GRASS using r.in.bin on Cygwin/XP.
Apparently, GMT 3.4.X type=1 grids are platform dependent. The header line in type=1 grids created on Windows (Cygwin or precompiled binaries) contains 4 extra bytes that are not found in a type=1 grid created on Linux. (for more information search the GMT-HELP archives for [GMT-HELP:11231] Problems with grdreformat on Cygwin and Windows )
r.in.bin assumes that the header in type=1 GMT grids conforms to the Linux convention, hence, any type=1 grids created on the Windows platform will fail to import properly.
The solution provided here is a small program that can strip the extra 4 bytes out of the Windows type=1 grids and convert them to the Linux convention (or vis-à-vis). Thanks to Marta E. Ghidella for this program.
How to proceed:
1) Create the GMT grid in Cygwin or DOS version of GMT as usual (Note the default grid type is type=0)
2) Use GMT's grdreformat to convert the grid to type=1:
> grdreformat ingrid=0 outgrid.win=1
3) Run convert6432.exe or convert6432.py as follows:
> ./convert6432.exe outgrid.win outgrid.lin -4
or alternatively
> python convert6432.py outgrid.win outgrid.lin -4
4) Start grass and use r.in.bin to import the linux-style GMT grid:
GRASS:~> r.in.bin -hf in=outgrid.lin out=grid
That, at lest, works for me on Windows XP with Cygwin
NOTE: To compile the C version of convert6432.exe in Cygwin, download convert6432.c to any cygwin directory and type:
$ gcc -mno-cygwin convert6432.exe -o convert6432.c
There is a fixed memory size in the C version that is adjusted by making the variable NMAX=4000000 larger and recompiling. This is unnecessary in the Python version so long as you don't run out of swap space.
David Finlayson
School of Oceanography
Box 357940
University of Washington
Seattle, WA 98195-7940
USA
Office: Marine Sciences Building, Room 112
Phone: (206) 616-9407
Web: http://students.washington.edu/dfinlays
(attachments)
convert6432.c (4.05 KB)
convert6432.py (2.74 KB)
