I have installed Grass 6.1 in Windows and now I want to integrate Grass with qGis 0.7.4. It's posible the integration? Or I have to use another version of Grass and qGis to get the integration?
Which are the steps to get the integration?
It's not yet possible to use QGIS + GRASS on Windows
because native port of GRASS is not yet ready.
It will be available soon.
Radim
I want to integrate Grass and qGis to use the plugins of Grass with qGis. I’m trying to start qGis with grass, but I haven’t achieved. So it’s imposible to get this in Windows?
To: Iñigo Telleria Elola tellenaiz@hotmail.com
CC: GRASSLIST@baylor.edu
Subject: [GRASSLIST:8950] Re: Integration of Grass and qGis
Date: Wed, 9 Nov 2005 11:46:40 +0100It’s not yet possible to use QGIS + GRASS on Windows
It will be available soon.Radim
qGis 0.7.4. It’s posible the integration? Or I have to use another version
Hi ,
Grass GIS for WIN is running only under CygWIN environment. It is not
Windows executable. QGis for Windows is cimpiled as standard Windows
executable. Result ? Native Windows executable for GRASs are not ready
yet. Answer : It is not possible run Qgis with GRASS support on
Windows platform.
Peter
I'm trying to start qGis with grass, but I haven't achieved. So it's
imposible to get this in Windows?________________________________
To: Iñigo Telleria Elola <tellenaiz@hotmail.com>
Date: Wed, 9 Nov 2005 11:46:40 +0100>It's not yet possible to use QGIS + GRASS on Windows
>Radim
with
version
Dear all,
I have installed on a pc running mandrake 10, qgis0.7.pre2 compiled with
grass 6.0.1
contemporary I have compiled PostgreSQL 8.1 and postgis1.0.4 with geos,
proj and plpsql....
I have used SPIT to import succesfully a points map into postgis...
I can see the map, I can edit the map to remove points but I can't
insert new points....
when I try to insert points qgis put the point into the map but when I
stop to digitize the result is that it can't commit changes:
parse-error invalid geometry
context: SQL function geomfromwkb statment 1
can you explain me ho can I solve this kind of problem???
or which step can I do to verify if the installation of postgis is
rigth...
thank you very much...
I have posted the problem on the qgis forum but I haven't got
answers....
Il giorno mer, 09-11-2005 alle 12:09 +0100, Ing.Peter Misovic ha
scritto:
Hi ,
Windows platform.Peter
> From: Radim Blazek <radim.blazek@gmail.com>
> >Radim
> with
> version
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini@unipg.it
ivan.marchesini@gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
But I can run qGis with Grass on CygWin??
To: GRASSLIST@baylor.edu
Subject: [GRASSLIST:8952] Re: Integration of Grass and qGis
Date: Wed, 9 Nov 2005 12:09:24 +0100Hi ,
with
version
