On Nov 10, 2005, at 4:52 PM, Andrew Danner wrote:
Helena,
I have attached a patch against the 6.1 cvs tree that should fix at
least the filled file having the wrong type. Internally, the code was
using floating point elevations, but when writing the data out to a
grass grid, it converted to integer type. I tested it on a sample data
set and r.terraflow now should produce a filled grid that is of FCELL
type.The flow accumulation is done on an internal representation that does
have floating point elevations, so if the flow accumulation routine is
generating unwanted results, it is not related to this output issue. The
problem with integer grids was simply an error when converting from
terraflow internal format to the grass raster format.-Andy
On 11.11.2005, at 00:38, Helena Mitasova wrote:
Andy, thank you very much, that explains it. In fact I never looked at the filled DEM
only at the resulting flowaccumulation. Florian, I will submit the fix and then can you please
test it again - the problems that you may see in the flowaccumulation result may not be
due to integers but due to many nested sinks that were filled. What kind of data and resolutions are you using?Helena
Helena, Andy,
thank you very much for your quick help and effort.
The patch fixed the problem. Now the filled DEM looks as it should.
Helena, regarding your question on the kind of data:
It is very high resolution data (1 meter or less) from airborne laser scanning.
So I suspected that maybe filled sinks lead to unwanted results - that's why I wanted to to take a look at the filled DEM in the first place.
Thank you that this is possible now
- Flo.
