[GRASSLIST:905] error compiling snapshot
Hello all,
I trying to compile the latest snapshot, since I want to use s.cellstats, but
./configure stops with a error msg:
checking whether to use GD... yes
checking for location of GD includes...
checking for gd.h... no
configure: error: *** Unable to locate GD includes.
Any help?
thnaks all
   Carlos Henrique Grohmann de Carvalho - Guano
    Geologist - MSc Student at IGc-USP - Brazil
       Linux User #89721 ICQ: 214752832
Any help?
The GD library is required for the PNG driver.
You can either obtain the GD library from:
  http://www.boutell.com/gd/
or use "configure --without-gd ..." to disable the check.
A similar procedure applies to the other optional dependencies; i.e.
either obtain the library (URLs are given in the REQUIREMENTS.html
file) or use the appropriate --without-??? switch to disable its use
(use "configure --help" to obtain a list of switches).
Each optional library is only used for a few (typically non-essential)
modules.
