On nie, 2005-11-20 at 14:59 +0100, Markus Neteler wrote:
On Fri, Nov 18, 2005 at 08:20:51PM +0100, Roger Bivand wrote:
> On Fri, 18 Nov 2005, Trevor Wiens wrote:
> > Now it is working, when I ran tracepath yesterday the system seemed to get caught in some
> > weird loop at an Italian internet provider. Some sort of endless loop between two machines there.
> > I found I could access via an internet proxy though. My guess is the provider in question
> > had their routing messed up.
> > I wonder if other people have had their access problems resolved too.
> Seems to be resolved through the proxy, yes.
I am not aware of any changes here, the server is/was untouched.
In any case consider to put me in CC, to get notified
immediately ... I didn't receive mails from Baylor for a couple
of days (maybe due to the same problem). Since today messages
arrive again from this list.
Markus,
I haven't got any problems accessing grass.itc.it ever. But I've had
problems with grasslist recently - at 17:00 (Poland) Wed 16.11.2005 I
couldn't post to grasslist being rejected for "Only list subscribers may
send messages to this list." while being subscribed AAMOF. Tried several
times after to noavail and finally re-subscribed which fixed the
problem. Thought you might like to know as you mentioned your grasslist
issue.
Here's the header of my rejected message if it helps to explain
anything:
Dear werchowyna@epf.pl:
Your recent message to the GRASSLIST list has been
rejected for the following reason:
Only list subscribers may send messages to this list.
If you need assistance, please contact the list owner at
GRASSLIST-request@baylor.edu
The text of your message follows:
Received: from fs-exchange1.baylor.edu (sisko.baylor.edu [129.62.3.211])
by ccis01.baylor.edu (8.9.3p2/8.9.1) with ESMTP id KAA1413147
for <GRASSLIST@listproc.baylor.edu>; Wed, 16 Nov 2005 10:07:23
-0600 (CST)
Received: from waylon.baylor.edu ([129.62.3.228]) by
fs-exchange1.baylor.edu with Microsoft SMTPSVC(6.0.3790.211);
Wed, 16 Nov 2005 10:07:23 -0600
Received: from willie.baylor.edu ([129.62.8.12]) by waylon.baylor.edu
Wed, 16 Nov 2005 10:07:22 -0600
Received: from mail131.pi.net.pl ([195.116.221.99])
by willie.baylor.edu (SMSSMTP 4.0.5.66) with SMTP id
M2005111610072132326
for <GRASSLIST@baylor.edu>; Wed, 16 Nov 2005 10:07:22 -0600
Received: (qmail 10117 invoked from network); 16 Nov 2005 16:07:21 -0000
Received: from unknown (HELO sorbus) (werchowyna@83.27.0.201)
by 195.205.153.131 with SMTP; 16 Nov 2005 16:07:20 -0000
Subject: Re: [GRASSLIST:9088] Re: missing Freetype includes - can't
build
cvs 15.11.2005, 23:15
To: GRASSLIST@baylor.edu
Cc: Hamish <hamish_nospam@yahoo.com>,
David Finlayson <david.p.finlayson@gmail.com>
In-Reply-To: <20051116143235.5039ab98.hamish_nospam@yahoo.com>
References: <1132094353.25818.3.camel@localhost.localdomain>
<be6d1720511151513h5b6e9ees494246f72bed73d5@mail.gmail.com>
Content-Type: text/plain
Date: Wed, 16 Nov 2005 17:07:30 +0100
Message-Id: <1132157250.26917.43.camel@localhost.localdomain>
Mime-Version: 1.0
X-Mailer: Evolution 2.2.1.1
Content-Transfer-Encoding: 7bit
X-OriginalArrivalTime: 16 Nov 2005 16:07:22.0886 (UTC)
FILETIME=[D42A4A60:01C5EAC7]
W polskim Internecie s± setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.epf.pl/
