[GRASSLIST:9131] v.transform
I got stuck trying to use v.transform.
I keep getting the follwoing error:  "Could not open file with
coordinates : comorgpc2"
The GCP file is in the PERMANENT mpaset in my current location.  It was
created with a text Editor, it contains 4 columns with coordiantes.
I tried renaming it and using different file extensions, but nothing of
what I have tried so far works.
Any clue to help me solve this problem?
Thanks
Armando Scalise
GeoInference
Patagonia Argentina
armando@geoinference.com
armandoh@gmail.com
I am not sure, but you might need to importthe file into grass first using v.in.asii. Alternatively you can use the cs2cs tool that comes with proj if you want to do this in a single step.
-Ian
Thanks
Armando Scalise
GeoInference
Patagonia Argentina
armandoh@gmail.com
What happens if a big asteroid hits Earth? Judging from realistic simulations involving a sledge hammer and a common laboratory frog, we can assume it will be pretty bad.
  - Dave Barry
This message has been scanned by Postini anti-virus software.
